Cross Border Charging Issues
Northeast
F150 Lightning - XLT SR (Max Tox / Pro Power)
Hello All,
I wanted to post about my recent experience using highspeed (50 kW +) chargers across the U.S. and Canada border. I frequently do 600+ mile round trips to northeastern Canada. My typical charging experience has been good with little to no issues. However, I have had two occasions now on the Canada side where I believe Plug and Charge is causing a major headache, and I wanted to share my experience in case anyone else ran into these issues.
The first occurrence happened when charging in June. We arrived at the charger after ALREADY successfully charging in Canada and plugged in as normal and followed the prompts on the charger. A few seconds after plugging in and the charger doing it's test cycle ("communicating with vehicle", etc.), the charger ramps up and then immediately stops. The vehicle says "charging interrupted", and the charger disengages. We tried multiple times, and received the same error. We also went to a different location and tried another highspeed charger and got the same error. We called Ford Canada to see if they could help. This was the most frustrating part of the entire experience. The people on the other side of the phone really did not believe or want to admit that the issue was with the vehicle or the Ford Pass app. They even said that because I had not had the recommended recalls done, it could be causing the issue.
After speaking with multiple people, we finally escalated the issue to Ford USA. They were able to identify the issue as a ford plug and charge issue, but they weren't exactly sure what was causing it. They were able to do "something" on their side that made it so the charger would initiate and stay charging. I wish I knew exactly what they did, but I was happy to be charging after spending 2 hours on the phone.
The second occurrence happened this past weekend. It is almost identical to the above (I should note, that we had done another trip across the border with multiple successful charging sessions). We immediately called Ford (unfortunately, because we were in Canada, it automatically routes us to the Canada team). Similar to my previous experience, Ford Canada was not helpful. They asked that I try plugging and unplugging the charger. Uninstalling/Reinstalling the ford pass app. Logging in/out of the ford pass app. Multiple times, over multiple operators. None of these options worked. I asked them if they could connect us with Ford USA, and they did. I talked with a very patient person, that suggested I toggle the "Plug & Charge" option to "off" under the "Access & Permissions" section of the "Energy" tab. Unfortunately, the previous Ford Canada person has asked that I deactivate "BlueOval Charge Network" under the "Connected Services" section of your account. When I did this, it completely removed the the "Access & Permissions" section under the "Advanced" portion of the "Energy" Tab. The Ford US person was surprised the options didn't exist. She asked that I go back into "Connected Services" and re-enable "BlueOval Charge Network". I did this but it did not change and the "Access and Permissions" did not reappear in the app. At this point, it was 10:00 PM and I was with my wife and daughter. We hung up with Ford USA and when to our hotel which had slow chargers (which we'd tested and confirmed they were working at the high speed charger site).
That night, the Ford USA person emailed and suggested I try her solution again. To my surprise, the access and permission returned, but the toggle for "Plug and Charge" would not stay in the off position. I pounded that toggle forty plus times.... nothing. I woke up the next morning, thought to myself, I may as well try the toggle one more time. It worked. It stayed in the "off" position. We went to the high speed charger, plugged in, and halleluiah it worked. I don't know what if anything the Ford USA person did on their side, but they went above and beyond to try and help me, even emailing me later to check in. Ford Canada was unfortunately ill prepared to help and admit the problem could be on their side.
For the record, I do not have Plug and Charge enabled as I don't find it convenient, but I believe that when Ford updated their phone app, it re-enables it, which caused the above issue. I hope this helps someone in the future. Sorry for the wall of text.
Many months ago we had seen reports of issues with the ability to toggle the P&C switch.
IIRC, it was a Ford server issue with their cloud systems, eventually it was resolved.
What day of the week was your negative experience, you mentioned "weekend" Sunday ??????
astrand1
Alex
Ford Fusion energi
Studio truck driver
I decided to turn off P&C. I use the app for the charger directly plus I pay the membership for Tesla so to get the better rate I need to go thru the Tesla app anyway.
Northeast
Sorry - we had taken a "long weekend". This occurred on Thursday.
I did see the previous post about the toggle issue. Thanks for your response.
Northeast
I think this is the smart move, at least until it is reliable. I feel like my situation was unique, but worth communicating to the community.
I love this truck, and 95% of my charging has been uneventful.
rickersondon
Don
Manassas VA
Ford lighting 2023
I had the issue in summer 2024 while on Ford Blue Oval. When you plug in, Ford interrupts the transaction to apply their magic. This often cause the transaction to fail and does not provide and discount plans you have with the supplier. I got off Blue oval and no problems since.
astrand1
Alex
Ford Fusion energi
Studio truck driver
I think for most who charge mainly at home and just occasionally DCFC P&C is the way to go. For me and some others that do cross country trips etc. saving money by being a member of some of these charging networks and using their app directly just makes more sense. 😁
climateguy
Ferndale, Washington
2021 Bolt, 2024 Flash, MaxTow
My calls to Ford for assistance with my Lightning have left me with a certain amount of skepticism about ever calling them again about anything. However....
Ford has announced what it is calling an improvement in this situation, aimed at improving the customer experience with their new Ford EVs. Ta Da! Taking effect starting October 1, 2024
(drum roll
 followed by trumpet fanfare)
Introducing: The FORD POWER PROMISE. ! Here is Ford’s “fact sheet” about it. The “Ford Motor Company” “Official Ford Account” here posted this announcement on this forum about it.
Ford is promising a new level of support for customers experiencing charging problems: 24/7 access to living human Ford reps. Customers initiate the support by sending a text. (I don’t think texts to the US can be redirected automatically to Canadian Ford reps if you are a US Ford customer texting from Canada, the way phone calls to US Ford from Canada can be automatically redirected.)
(This could be an actual improvement - I once called Ford’s customer service line on a Sunday and discovered they don’t answer the phone on Sundays)
Ford’s promo material could be interpreted to mean this 24/7 support is for Ford EV owners experiencing any kind of problems with their vehicles.
Customers need to sign up for this access:
Ford F-150 Lightning Cross Border Charging Issues Sign u
Already an Owner? Sign Up
Apparently, the Ford Roadside Assistance Program has been expanded as part of this new Ford Power Promise program, to include towing to a charger if you think you are running too low. Quoting from Ford's 24/7 signup page promo:
"Plus, Ford Roadside Assistance now offers proactive charging support and towing, giving you peace if mind if you ever run low on charge."
I thought we already had Roadside Assistance. I haven't read the fine print on this. It may exclude access to this possibly extra, not offered until now, assistance if you are a US Ford customer looking for a tow in Canada....
Hope springs eternal. I'm signing up right away.
I don’t use Plug and Charge. When I have charging problems I call the charger company. I haven’t suspected, yet, that the problem could be the vehicle so I haven’t tried to contact Ford over a charging issue. I did call A2ZEV when I experienced problems with my new adapter the first time I charged at a Tesla charger - their customer service is fantastic.
Here's the message I got when I succeeded at signing up for this new level of assistance:
Ford F-150 Lightning Cross Border Charging Issues you're in
srspring551
Scott
WI
F150 Lightning Lariat 2023 ER, delivered 10-28-23
Although I didn't initially recall doing this, I clicked the link, and saw this. Looks like their hours are quite restricted. Good thing that "problems" only occur M-F 10 am - 8 pm EST. :lying:
Ford F-150 Lightning Cross Border Charging Issues ford text
