DCFC precondition temp
For those who monitor your car regularly, what temp do you see the battery warmed to when preconditioning for DCFC?
mparz00
Capital District, NY
'22 Lightning XLT SR, VW ID.4 AWD Pro
Firn, this has been discussed in a number of threads. Unless something changed in a recent update, the Lightning does not precondition the HV battery. Only the MachE has this feature.
WaterboyNorCal
Erik
2023 Ford Lightning XLT SR
Uh, what? If “the Lightning does not precondition the HV battery”, why on earth would Ford explicitly say that it does? Furthermore, this has been discussed at length on Reddit and the various F150 Lightning forums, and this is the first time anyone has suggested that it’s only the Mach-E that preconditions for DCFC. Mparz00- please kindly cite your sources.
B177y
Olympic Peninsula WA
www.ptcoffee.com
2024 Lightning Pro ER Max Tow
Coffee Roasting
I have monitored my battery a few times while using Google Maps for nav to a DCFC and CarScanner for the data.
HVB temp has only risen to 59.8 deg F from a starting point that was 48 deg F.
The AC compressor (heat pump) and coolant heater (resistance heat) both are active and using power during this time.
OK, that makes sense, thank you!
Ford F-150 Lightning DCFC precondition temp drew-scanlon-white-guy-blinkin
