Disappointment Thursday
p52Ranch
Bryan
OK
Standing on the loading dock waving goodbye to the rail cars rolling out of Dearborn.....
I checked with Ford chat yesterday and my status was released and waiting to be shipped so I am trusting that mine is just in the queue waiting it's turn for an OKC bound rail car.
ah requires a vin number, maybe one day ill receive one lol
Have you been assigned a build week yet?
If so, then ask your salesman for it along with a copy of your WBDO order sheet
p52Ranch
Bryan
OK
can someone explain the back door way of checking for build date
The "Backdoor tracker" really isn't a Backdoor with the Lightning reservations and orders as you get the "View" option which navigates you to the https://www.ford.com/buy/manage.html?reservationId=xxxxxxxx screen where xxxxxxxx is your reservation/order number.
The Bronco reservation does not provide that link and instead has "Contact Dealer" which just gives you your dealers info. But you can use the link above and insert your Bronco reservation number to access the same screen. Hence the "backdoor tracker" because you needed to know the HTTP link.
Ford F-150 Lightning Disappointment Thursday 1658506665937
Regarding Build date there are a couple of other trackers that can be used. First you must have an order and not just a reservation. Second your Lightning needs to be scheduled for production and you must have the VIN and know the 4 character DORA order number the dealer assigned for your order. You can then use one of these links
https://shop.ford.com/vehicleordertracking or
https://shop.ford.ca/vehicleordertracking
to determine your build status. These tracker are a bit maddening as they are finicky and only work maybe 50% of the time.
If you have a VIN and a Window sticker then you can use
https://www.windowsticker.forddirect.com/windowsticker.pdf?vin=
where you insert your vin# after the = The window sticker will give you your blend date which is when it is planned on starting the process of rolling down the assembly line.
bewbie
NYC
not assigned yet, wave 4 ordered 2/17 Lariat ER Tech Tow AMB
Then you need to get to that stage by monitoring your personal order page, once you have a build week, then follow the previously mentioned steps
My Vehicles
Trick
NJ
4runner
Wave 5 order and still nothing, reached out to the dealer and they said it looks like its getting pushed to 2023, trying to get more info.
Any way to get the 4 digit order number other than through your dealer? I already got my VIN via the developer console truck.
It will be on your window sticker once it's viewable, until then there is not much to see or track on the SHOP or ORDERTRACK sites, this is my order number
Ford F-150 Lightning Disappointment Thursday 1658518349161
VTRedWingsFan
Vermont
2023 F-150 Lightning Lariat ER, 2020 Escape
IT delivery
Wave 7 , EB, Smoked Quartz, not scheduled.
PV2EV
Not sure of Ford processes, however, with 7/28 being the last day to change MY22 orders, should we expect everyone to get build weeks shortly after? Should that also facilitate getting blend dates for those with a build week? And also, an end to changing build weeks?
p52Ranch
Bryan
OK
I scoured the developer console and did not find my four character order number anywhere in it.
Do you have a "Preview order" or WBDO print out from your dealer? It will be on there. It looks like this: The order number shows up twice on the preview order sheet.
Ford F-150 Lightning Disappointment Thursday 1658520043498
If you have your Window Sticker it is here:
Ford F-150 Lightning Disappointment Thursday 1658519016056
I'm learning as I go here, but what you stated makes sense, given past history, they might do another blast of build weeks in the first or second week of August, filling remaining slots for late August and all of September, once done, does not make sense to shift folks around as they are closing in end of production for MY22 week starting 10/3
YankeeCP
CP
Jacksonville
2023 Lariat SR Lightning
Checked in with the dealer today- my dealer still had not heard anything about 2023 but did confirm I was 3rd on the list.
