Dreaded Service Vehicle Soon Error
I seen the Shifter issues some were having, and played with mine a little. I don't think it's that since it wont charge. I had someone on here run the VIN and its throwing P0B24:21 "EV Battery "A" Voltage Unstable: Signal Amplitude Less Than Minimum"
I do have another charger but haven't tried it. Been a little under the weather today, but I will try it later. I appreciate it the help.
I was referring to the onboard charger, not your EVSE. With that code, I don't think the onboard charger is the issue anymore. That duck is quacking like a bad battery module. :(
I'd call the BEV hotline and start a case number before you take it in. Might help get things rolling quicker.
AmandaB
AmandaB
US
2022 Ford Lightning Lariat ER - Red
Ahh gotcha. I'm still hopeful its just something minor but realistically I know its not. Too many instances of this happening. I did send Ford a message on here and they made note of it, but I don't have case number yet.
ivan256
Massachusetts
2022 Lightning Lariat ER
This week was my week for this issue as well.
Had the truck in for 30k service and tires last Monday. When I got it back my range was low, but I never trust the estimated range anymore anyway...
Thursday I drove it 180 miles. I told it to charge to 100%, and had set a departure time. When the time arrived it was only at 98%, which was weird. And it seemed like I had no - or significantly reduced - regen braking. I ended the trip below 30% charge, which is way worse than usual... I thought it was the tires? Then it failed to charge overnight. It said it was a charging station fault (Using the Ford Charging Station Pro). I had to stay home because I didn't have enough charge to get to work Friday, but it did charge to 80% (my set limit) during the day.
On Saturday I needed to make the same 180 mile trip, so I set it to charge to 100% again. It only made it to 87%. Then the light came on. Dealer hasn't had time to look at it yet. And I'm not sure what I'm going to do without a truck for more than a couple days. -sigh-
AmandaB
AmandaB
US
I can't charge at all. Are you getting reduced power as well?
Also, I've seen some say Ford BEV paid for a lot of people to have a rental if it gets to that point for you.
ivan256
Massachusetts
Yes.
Ford F-150 Lightning Dreaded Service Vehicle Soon Error 1731950983522-v
When the error first came up it didn't show reduced power (or I didn't notice?), but after a few miles it dropped down to 59%, and then on the way to the dealer 56%.
I had the power reduction issue happen once during the summer at full charge, but without the error message and the wrench icon. I took it in, but it didn't happen for them, and I've been driving it since without issue until now.
AmandaB
AmandaB
US
Yes.
When the error first came up it didn't show reduced power, but after a few miles it dropped down to 59%, and then on the way to the dealer 56%.
Mine started at 54% and is at 57% reduced power right now. Both motors show they have power and it drives fine, but without being able to charge I had to stop driving it when It hit 62%. Dealership is 40 miles away so I didn't want it to get too low. Good luck getting yours fixed!
ivan256
Massachusetts
Good luck with yours as well!
Hopefully the parts are flowing faster these days...
