Red ring and service vehicle soon?
10er
10er
Tenor
NY
2023 Lightning XLT
Left work early and came home to try and trouble shoot this...plugged it in and it started charging with no issues....10 minutes later I get a charge fault notification from the app....it did add 5 miles of range, so it was working for the short amount of time that it was plugged in before the charging fault.
10er
10er
Tenor
NY
2023 Lightning XLT
Solid red means issue is with truck, flashing red the issue is with the EVSE
Yeah, it's solid red again now...wondering if I should try and use the mobile charger to see what happens
jimfigler
Orchard park, NY
E306677
Note: Charging faults are identified by the
color amber on the charge status indicator.
Faults can occur within the vehicle charging
system or outside the vehicle, such as with
the mobile power cord, charge station or
electrical supply.
Note: If the system detects a fault in the
vehicle charging system at any point in a
charge cycle, the entire charge status
indicator illuminates a solid amber color for
30 seconds and then turns off. If this
happens, unplug the charge coupler and
plug it back into the charge port receptacle.
If the problem persists, have your vehicle
serviced as soon as possible.
Note: If the system detects a fault outside
the vehicle, such as with the charge station
or mobile power cord, the entire charge
status indicator flashes amber continuously
for 30 seconds and then turns off. If this
happens check the mobile power cord,
charge station or electrical supply.
10er
10er
Tenor
NY
2023 Lightning XLT
Yeah, mobil charger showing solid red as well....I had a brief glimmer of hope when I got home and it started to charge, but after that initial ten minutes it's just stayed solid red
flyct
Jerry
South Florida
Blissfully Retired
The good news is that you should be able to use a Public DC Fast Charger if you are in the need of a charge in the mean time. The DCFC bypasses the truck's internal charger.
tubby
Press
Iowa
Many will likely disagree, but I would still put bets on warming the truck batteries up overnight somehow. Others might even suggest to restart the truck sync system. If you have a spare vehicle and you do not have a warm place, see if your local Ford dealer can at least put it inside overnight for you...if they are not too far away.
The Weatherman
Dean
South Central KY
No expert here, but I’m betting on it being the onboard charging system, not the HVB.
That failure will almost, if not always, present a reduced power % on the dash.
10er
10er
Tenor
NY
2023 Lightning XLT
Plug share is showing a DCFC down the road. Ive never had the need to use it, so I never knew it was there. I think I'm going to go try it and see if I can get a charge
10er
10er
Tenor
NY
2023 Lightning XLT
No dice...solid red ring, wouldn't connect and to top it off I've got a pending EV connect charge for $25.....hopefully it doesn't go thru
TMND
usa
Lightning
ag
Port on truck. I betcha
tubby
Press
Iowa
I am tending to agree. If you want the GROK3 answer, here you go.
A solid red ring on your Ford F-150 Lightning's charge port while using a DC fast charger (DCFC) indicates a fault in the charging system. DC fast charging, unlike Level 1 or Level 2 charging, is a high-power operation, and a solid red light signals that something is preventing the charging process from happening correctly. This is distinct from a blinking red light, which indicates active DC fast charging.
Here's what you should do:
  1. Stop Charging Immediately: Do not continue to try to charge the vehicle. A persistent fault could potentially damage the battery or charging system.
  2. Check the Charger Screen (if applicable): Many DC fast chargers have screens that display error messages. See if the charger itself is reporting a problem. This can often provide clues about the nature of the fault.
  3. Check the FordPass App/Truck Display: Look for any error messages related to charging on the FordPass app or the truck's touchscreen. These messages can be more specific than the red light and help diagnose the issue.
  4. Try a Different Charger (if possible): If another DC fast charger is available, try using that one. This helps determine if the problem is with the charger itself or with the truck's charging system.
  5. Restart the Truck: Sometimes, a simple reboot can resolve temporary software glitches that might be affecting charging.
  6. Check Cable Connections: While less likely with DC fast charging, ensure the charging cable is securely connected to both the truck and the charger.
  7. Contact Ford Customer Service or Your Dealer: If the red light persists after trying the above steps, contact Ford customer service or your dealership immediately. A solid red light during DC fast charging indicates a fault that requires professional diagnosis and repair. They have the tools and expertise to troubleshoot the issue effectively.
Do not attempt to continue DC fast charging with a solid red light. It's crucial to get the problem diagnosed and fixed by a qualified technician to avoid potential damage to your Lightning's charging system or battery.
acbarba
Enrique
2024 F150 Lightning Flash
Assistant Fire Chief
Not sure if it's related to the same issue however, I was getting the red ring of death, charging fault and service vehicle soon. Mine was specific to Fast Charging. My dealership order me a new Charging port. Still waiting for it to be delivered.
Bwanapete
Peter
Cazenovia, NY
2022 Lightning, 2023 Tesla MY, 1941 Lincoln V12
I had inability to charge at home but could charge on a Supercharger. Dealer found the trouble: a rodent had lunched on some soy based wire insulation. Dealer spliced around the damage and applied the Honda wire wrap and applied peppermint oil. So far so good.
jamelski
Sacramento
2024 Lariat
@10er ill put money you are having the same issue I had. Mine was the SOBDM module that’s behind the frunk.
