Jesse-Infotainment
What I am saying is DO NOT load all from an old back up.. You can make changes but dont load all
It no longer appears in the software tab, the only thing I have is the GSM procedure. The update failed, but it still cleared itself out and I can't get back in.Did you pull the USB stick out first? Or did you mean the update no longer appears in the SW tab?
Are you referencing changing the
@Bob_Mac yes I made changes for adaptive headlights to the two below
720-01-01. 22FOA 3064 F4EA
720-10-01. 0B18 0061 00BC
Slow down. Do a network scan. Are you getting DTCs? You need to check this FIRST!Are you referencing changing the
Can you change the values back to what the originals ones were? If you don't have them then try this as last resort.Are you referencing changing the
I hope no one is doing that...What I am saying is DO NOT load all from an old back up.. You can make changes but dont load all
Can you run the IPC from scratch now? Erase the flash drive and start again as if you’d never touched the IPC before.@JEB sorry, yes I did a network scan and the module came back green with no DTC’s also the IPC update is still present. All modules are green and no dtc’s present on any module now.
Well When I saw it mentioned someone had a structure mismatch that is why.. So I just wanted to make it clear not toI hope no one is doing that...
Please look at what I posted... your FORScan changes could be affecting the update. The last line stays only the first one I posted gets changed. The last 2 of the last block will get recalculated if it's wrong.@JEB sorry, yes I did a network scan and the module came back green with no DTC’s also the IPC update is still present. All modules are green and no dtc’s present on any module now.
Right there with you... I had them do only a single change...Well When I saw it mentioned someone had a structure mismatch that is why.. So I just wanted to make it clear not to
Did you make ANY changes to the IPC using FORScan?It no longer appears in the software tab, the only thing I have is the GSM procedure. The update failed, but it still cleared itself out and I can't get back in.
That does NOT pertain to their issue. The IPMA has been cleared back a few posts ago. Don't need people doing these things if it's not necessary!IPMA errors
Not that I remember. Let me look back through my changes.Did you make ANY changes to the IPC using FORScan?
Disable driver & passenger seatbelt minder | IPC | 720-01-01 | xxxx | xx0x | xx-- | |
Disable Auto Engine Idle Shutdown of 30 mins | IPC | 720-01-01 | x*xx | xxxx | xx-- | subtract 8 from your default value (if default is F, change to 7) |
Let me ask it another way... have you done any FORScan changes?
