imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
Can you check node F120 for the software version? I’m guessing it will end in FCA—the mirror image of what mine did.
- DID F120 - MU5T-10F906-FDA
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
I have a request :)
I would really like it if someone could begin documenting all of the strategies and part numbers associated with the different power-up versions. I would like to be able to identify which power-ups have been installed in the widget.
imnuts
Dirty Jerz
Facilities Engineer
I decided to just bite the bullet and do a network scan to see if anything else showed up. I did have another DCACA module update show up, but I'm not sure if it actually did anything. The ABS update disappeared. I tried to re-run the GWM update, but nothing happened that I could tell and it stayed in the list. Now to keep my fingers crossed that nothing major happened with the data sent back to the cloud to prevent future updates.
I did see that the IPC had a DTC set, it was U2100. Looked through the thread and saw the recommendation to just run the PMI process. Did that and the DTC disappeared. I checked ForScan afterwards as well and I no longer have any codes anywhere, as the trailer module update cleared that code.
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
Thanks. So F120 and F188 are the same for you, different by one character for me. Probably prepping for BlueCruise.
I know you weren't asking me, but I have the same F120 MU5T-10F906-FDA
but my F188 ends in FCA rather than FDA
Wish I understood more about the DID values and their significance.
(I recently applied the IPC USB/CAN update)
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Yours and mine are the same.
@imnuts , what are your versions for F120 and F188 now that you’ve run the PMI to clear the DTC?
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
The IPC update seems to be ok now. They seemed to have sent out the correct update.
Edit.. The IPC is TWO parts - I know I mentioned that previously. First is a USB update and the last is CANBUS So please pay close attention as you do it.
This brings up a very important question, those of us who only had one file will we see another update since it was corrected?
JEB
Northern Illinois
First, check nodes F120, F124 and F188. If F120 ends in FDA, F188 ends in FCA and there is nothing at F124, you are up to date. Don’t worry about it.
Jesse-Infotainment
Jesse
2024 F150 Lightning Flash
That’s the real issue. Speaking with @JEB if I understood him correctly he had an issue and then did a PMI and it did another update during the PMI and he has been confirmed to be at the proper files.
So you could try a PMI to see if it detects the needed files. I had to side load the files. It took hours and hours but did get it finished: it was the cluster that went totally blank and it came back to life. I did the side load in the order the update did it.
Snakebitten
Coastal Texas
Bob, I originally had the 1 file update like you did. And I applied that update.
But the next time I looked, FDRS had an IPC software update available (more than 1 file) in the "ALL" section (when you click the IPC module on the left screen), rather than the SW Updates section.
I applied THAT one and it required both USB and CAN procedures.
I have no idea why that update was listed where it was. I almost missed it.
jcaspar
Jeff
Sacramento CA
2021 F-150 4x4
Anyone have trouble with their running boards after updating? am now up to date is seems but my power running boards are stuck out. Only DTC is on the IPC, cannot get this one to clear. Fuse is good and ran tests on DSM, BCM BCMC all good. Interestingly, when I ran a self test of the BCM after updating it (had a DTC) I it had very violent movement of the running boards. Did not do that this time.
JEB
Northern Illinois
Yep. That’s what happened. But it was quick. The DTC related to a failure to properly configure the module. When I ran the PMI, it quickly flashed that it was retrieving new software but what I didn’t see was the slow, arduous block-by-block CAN bus update we’ve seen for larger updates. So it either retrieved a small file that installed quickly, or it retrieved a file, decided it wasn’t needed and then just proceeded to complete the configuration without installing new software. No way to tell for sure. But the PMI absolutely said it was grabbing new software.
Bob_Mac
Bob
North Carolina
I had to do the PMI as well but don't recall the CAN update. I just did another PMI and I did see it this time.
Bob_Mac
Bob
North Carolina
I match with F120 & F188 but the before and after AsBuilt after doing another PMI (just now), I do not have F124 with either...
Bob_Mac
Bob
North Carolina
rtgh
The "All" is all the tabs in one location so I'm stumped why it was there and not in the SW Updates tab... I also confirmed this with the pesky GSM update that won't go away.
