F150 Lightning FORscan thread
Status
Not open for further replies.
dippinMike
Torrance, CA
2022 F150 Lightning Lariat
damn, yeah it’s annoying lol
I returned mine to stock but I made the change that takes away the “Full View Not Available” when tapping the camera to show the rear view when i’m driving. I think i’m good with that, not sure what I would use all of the cameras for when at speed
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
Along the same lines as the cameras at speed, has anyone found if its possible to use the mirror spotlights above 7mph?
Blochead21
PA
Black 22 XLT 311pkg
Not that I’m aware of. But there is a way to jump the power signal to the right pin that used to be done on older F150s to enable the lights at any speed, not sure if anyone has tried this on the lightnings.
Abominable
Robert
Arkansas
2024 Ford Lightning Flash
Auto
I've got a 2024 Flash with trailer tow package and pro power 9kw and I cant seem to get the matrix lights to work. every time i get to the IPMA it fails to make the change. anyone have any insight on why this is? was able to change everything else except this.
Blochead21
PA
Black 22 XLT 311pkg
Check with Forscan directly. I would imagine your flash may not be recognized by Forscan and a beta version is probably needed. You will need to sign up for them to support you. It’s like $13.
Abominable
Robert
Arkansas
Auto
I understand. I didnt know there was more hardware that was required. My flash definitely has the "bending" headlights. It just seems more like a software problem rather than hardware as it wont let me edit anything in the IPMA section of forscan. it just fails to make the change every time. Again, thanks for the info.
Abominable
Robert
Arkansas
Auto
will do. again, thanks for the info. I'm sure its just forscan not being able to read/write the IPMA correctly, so it fails.
Abominable
Robert
Arkansas
Auto
Just a little update… got a test build from forscan and got my glare free headlights working after Ipma kept failing at 8%. After I received the test build, it works great!
In summary;
Confirmed glare free headlights working on the 2024 Flash with tow package and pro pack.
In summary;
This is likely some information that could be of use over on the ICE forum. I believe they are having troubles with the '24 ICE getting Glare Free enabled and even for Canada trucks they are not coming enabled from the factory. This could also indicate a change for the ICE truck hardware.
Status
