BabyDoc1012
Yep yep not a problem, glad to help. On the link scroll down and there is a tab called installation and it has a video on the process.Ah. I’ll take a look at the video. Thanks!
Just watched it. I’ll check it out in the truck tomorrow. Thanks again!Yep yep not a problem, glad to help. On the link scroll down and there is a tab called installation and it has a video on the process.
Not a problem, glad to help out.Just watched it. I’ll check it out in the truck tomorrow. Thanks again!
Tomato PotatoYou can create a new one, but you can’t change the factory code.
It does not seem to work for my 23 ProI just discovered that of you press and hold the volume knob, it activates the calm screen.
Big knob on the 15” screen.It does not seem to work for my 23 Pro
I guess size matters after allBig knob on the 15” screen.
The wireless phone charging pad has a fan underneath that automatically turns on and off when you place or remove a phone from the pad respectively.
This is interesting. I've seen tons of complaints on here about the wireless charger but I use it daily and while it's certainly slower than a cable I have had no problems. But I do have a Platinum and there is a fan. Thought everyone had it!I didn't even know that was a thing for the platinums. Pretty certain my Lariat does not have it. Last time I tried to use it, it got so hot it shut off Android Auto and stopped charging. I gave up on it after that and just plug in to keep the phone topped up.
Open Youtube, make sure you're signed in of course, then there is a "compass" icon in the top left. Click that, and you should see the option for Youtube TV toward the bottom.How do you do that? I have played around a bit and can't figure it out. Thanks!
This assume you have been able to load the YouTube app. I've tried to add it on my XLT, but no joy. Maybe it's a Lariat and higher trim level thing?Open Youtube, make sure you're signed in of course, then there is a "compass" icon in the top left. Click that, and you should see the option for Youtube TV toward the bottom.
To enter calm screen on the 12” screens use the physical button below the screen that looks like a screen with a line through it. Press it again to turn the screen off.It does not seem to work for my 23 Pro
After you punch in the code to unlock the doors, hold the 7/8 button for a second or two.
It's a great alternative for when the door handle nipple won't respond at allAlso, pressing 7/8 and 9/0, at the same time, will lock all of the doors.
