Lack of OTA Updates...Am I the Only One?
rugedraw
Javier
Miami
Auto Sales
It's listed on the software update screen. Mine is "Ford Power update 4.2.2.2"
I can send you a photo if that helps. I've been on that version for well over a year and when this thread went quiet I started to think I might be last in line. Turns out I'm (still) in good company.
He is referring to the Sync version you can see in the "about sync" menu in your touchscreen. Your truck is on 23031 which is one version newer than his.
The nice thing is that I'm still able to enjoy the truck, I'll hit 30k this week. I don't really *need* most of the updates available. The big one I'd like to try out is enabling BC 1.3 so I can try it out before my free trial ends next June. I really like using it, except when passing large vehicles. I also had a lot of ping-ponging from time to time (may have been from strong cross winds). The updated version is supposed to have fixed those issues. Not sure I'll pay what Ford wants for it, but I'd still like to try it.
ZSLC
Zach
Salt Lake City, UT
F-150 Lariat Extended
Curious where you find the 22326 version number? Do you need to run FDRS or is it in a menu I am missing?
I was just checking my update status on FordPass and noticed it says I'm on 6.1.0 now. I don't recall ever getting notified and then remembered that my dealer pushed an update. Sure enough, the date lines up. So I'm at least in the 6's now, but still waiting on Ford to do its job and send me something OTA.
jdmackes
2023 F-150 Lightning Pro
I've gotten a few OTA updates, but I have no idea what power-up version I'm on. Last ones I got were 24.2.4.9 and 24.2.4.10. Every once in a while I'll see the little bell icon for an update, but when I got to the update screen nothing shows up (aside from the last installed update information). 24.2.4.10 happened to install the day after I unplugged my battery so that I could redo my steering wheel. Dunno if that was a coincidence though
rugedraw
Javier
Miami
Auto Sales
I believe Ford is doing away with the "Power-Up" theme. The latest 10.x.x OTA's are no longer referenced as power-ups and these 24.x.x.x ones do not mention it, either. That's not to say you still can't get one of the 6.x.x updates if your truck missed out on one for any reason, like 6.5.0 for the SCCM and 6.8.0 for the IPC. However, if you're getting the 24.x.x.x ones, you're mostly likely done or close to being done with the power-up ones.
jdmackes
I still don't have 6.8, at least I assume I don't. I don't have the battery percentage showing on my screen at least, and from what I understand 6.8 is what gives that.
Not sure where I'd rather be, not getting any updates or not having the SOC update. On the one hand, I did get the original update that added it, prior to it moving to 6.8. On the other hand, I've not received an OTA in almost 1 year (about 1 week shy of that anniversary). Dealer has pushed all available CSP's and they even gave me 6.1 to try and spur the OTA's to start. That was 3 weeks ago, no luck so far.
