Limiting cabin outlet to 360 watts or 3 amps possible
Dino
Dean
Nashville area
23 XLT Lightning, 22 Volvo XC 60 plug-in hybrid
Is it possible to limit the cabin outlets to around 400 watts/3-4 amps while the truck is parked? I have pro-power onboard, but just asking about cabin outlets and without purchasing any external products.
Ok - I am very curious as to your intended use case where you would need that limit.
Dino
Dean
Nashville area
To be able to recharge an external battery at around 400 watts instead of 1800 or so watts.
tls
New York
2022 Lightning
How are you envisioning this would work? The battery is a DC load. It's attached to the truck's 120V AC outlets via its own (the battery's) charge controller, which controls current drawn by the battery by adjusting its (the charger's) output voltage. How would the truck control this?
Sedawk
2023 XLT ER
Just use a charger where you can specify the max charging rate - limiting the power source seems like a strange request.
Dino
Dean
Nashville area
I am not talking about any of the truck batteries but an external battery power source. I just want to be able to recharge slowly.
That would be the job of the battery charger, not the truck.
Dino
Dean
Nashville area
Just making sure I was not missing anything in the truck Pro power settings, thanks for the quick replies.
TomB985
Isanti, MN
2022 Lightning XLT ER
This. If the load is greater than the power source can supply, something has to give. A 400w inverter would blow a fuse if you plugged an 1,800w load into it.
The only way to charge a battery slower with a 120v AC power source is to use a slower battery charger. Just out of curiosity, what kind of battery are you charging, and why do you want to charge it slower?
