- First Name
- William
- Jan 8, 2022
- rural Georgia
- 22 LIGHTNING PRO IcedBlueSilver 8/23/2022
- Occupation
- Owner
TESTED: SUCCESS!
you now have an additional 240v 20amp OUTPUT at the rear BED outlets, via a 'Y' adapter:
here's the 'Y' adapter(two 30amp 120v male to a single 50amp 240v female, using two 30amp to 20amp adapters to the BED outlets) setup.... while there is such a thing as an adapter that can go from 50amp 240v female to TWO 20amp 120v males, those are rare... since I have a camper and often use these 30amp to 20amp adapters, I had two on hand, which made this TEST easy...
It's great to find ADDITIONAL 240v output, IF you ever need it... NOW WE KNOW : )
The 240v OUTPUT verification means that you can use BOTH the onboard ProPower 30amp 240v twist-outlet, along with ANOTHER 20amp 240v output with these adapters... giving you much more 'available' 240v power, and WITHOUT having to have the HIS(Home Integration System) that is very expensive. Yes, you only have a total of 9.6kw of output, or put into 240v terms: 40 amps, but that extra 10amps might be just what you need. You can use the full 20amps from this 'new' 240v output, or you can share it with the existing 30amp output, as long as both, together, don't go over 40amps, or either exceed their 'own' limits, 30 or 20.
Here's the reason this WORKS: Ford designed the LIGHTNING with a 2.4kw 120v 20amp output, on a single inverter, with outlets within the Frunk, the Cab, AND one set in the BED.
When you 'upgrade' to the ProPower optional 9.6kw OUTPUT, you get a SECOND inverter, on a DIFFERENT phase, with the 30amp 240v twist-lock outlet, AND an additional set of 20amp 120v outlets in the BED. These 'additional' outlets are on a DIFFERENT phase from the neighboring 120v outlets, and allow this 'combining' of two 120v circuits to create the 240v output we want. THANK YOU FORD.
I believe that the 30amp twist-lock outlet, and the two 20amp outlets directly underneath are on the REAR bed inverter, and the neighboring two outlets are on the FRONT inverter, with the Cab and Frunk outlets.
CONGRATS! : ) woop!
CONGRATS! : ) woop!
