Motor Coolant Over Temperature Warning – NOT Just A Software Glitch
The Lightning has one expansion / degassing tank
GoodSam
Good
occupying space
Another possibility?
https://www.carcomplaints.com/Ford/F-150_Lightning/2023/tsbs/tsb-tsb-23-2316.shtml
Ford TSB #TSB 23-2316
2023 Ford F-150 Lightning
MC-10244719-0001.pdf
Affected Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM/PCM/TECM)
Summary
Some 2022-2023 F-150 Lightning vehicles may exhibit an illuminated powertrain temperature warning lamp accompanied by a Motor coolant over temperature message in the instrument panel cluster (IPC) with DTC P0A3C:94 stored in either the secondary on-board diagnostic control module B (SOBDMB) and/or the secondary on-board diagnostic control module C (SOBDMC). This may be due to the software within either the SOBDMB and/or SOBDMC. To correct this condition, follow the Service Procedure to bring both modules to the latest software level.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
Amazing that you remember that. Yes I did. But is that the same coolant? Is the coolant associated with the battery the same coolant for the motors? I'm ignorant!!
Since this thread got resurrected I'll chime in to clarify for the record. The battery and motors have separate coolant circuits but there is a balancing valve and a single expansion tank. That allows for separate monitoring and control of battery and motor temperatures with a single point for filling and level check for convenience.
And the coolant is the same yellow Ford coolant used on their ICE vehicles.
FirstF150InCasco
FirstF150InCasco
Boston MA
F150 Lightning
Super info. Thanks for the clarification.
Lytning
Georgia
The EV Tech told me that the published air purge procedure did not successfully remove all air, and that he had to repeat it multiple times. I doubt it would have been repeated multiple times if I had not identified it as a line item. I do not have access to the procedure, though.
As a follow-up, even after the dealer repeated the air purge several times, I found the coolant tank well below the minimum level on 2 or 3 occasions after I got my truck back from the module replacement. It finally stabilized after that. I suggest checking the coolant level frequently for several weeks after a module replacement.
