idahospud
Idaho
2022 F150 Lighting, Indian Roadmaster
Commercial Real Estate
tearitupsports
Russell
Houston, TX
Did you commission the HIS? He is a link to directions for commissioning. https://docs.google.com/presentatio...wHGKRshc/edit?pli=1#slide=id.g1536e0dbd98_0_0
Also, I have included a link sent from Delta about the installation of the system in general. https://sites.google.com/sunrun.com/sop/sops/ev-chargers/ford-ev-charger
Once the installation "bugs" were worked out, my system has been working flawlessly (no solar or battery though).
Thank you for the info.
I have gone through all those documents and paired the truck to the charger a few times. The last time went the best, but still no backup.
Would you be able to confirm a couple items? Is there anywhere in your ford pass app that HIS shows up? My in truck app shows it paired and waiting to start, but there is nothing in either ford pass, or the charge station pro app to indicate it is paired on that side.
Do you use the M-professional app with the inverter? If so can you PM me a snapshot of your summary page? Also confirm the system settings (import/export settings you use). Lastly the power light on your inverter...does it blink once every 5 seconds or is it solid on, when you are on grid power?
Thank you!
idahospud
Idaho
Thank you!
Regarding the Ford Pass app, under the charge station there is a Home Backup Power option. I have attached a screenshot. I did use M-professional. The Power light flashes while on standby, I will check the status of the light during "power-up" next time I test the system. I will save a screenshot of M-professional when i get home.
Ford F-150 Lightning My new Ford Home Integration System + Battery installation project 1725494164751-6x
tearitupsports
Russell
Houston, TX
Thanks. I actually think this might be my issue. I’ve successfully paired the station to the truck but the station doesn’t show enabled like yours and others. Any idea how this gets completed? Is it something Ford has to do?
You can see mine is different.
Ford F-150 Lightning My new Ford Home Integration System + Battery installation project IMG_1939
tearitupsports
Russell
Houston, TX
New update. The system finally worked for the first time today. I have not changed anything except I recently received OTA 6.14 as well as ECG-24.2.5.6.2 - Vehicle Communication.
It worked on the first and only try today. I am now going to move my solar over to my backup panel and install the LG battery.
Ford F-150 Lightning My new Ford Home Integration System + Battery installation project IMG_1993
Ford F-150 Lightning My new Ford Home Integration System + Battery installation project IMG_1995
tearitupsports
Russell
Houston, TX
I now have the installation permanently wired in and running. I also now have my existing Solar Edge inverter tied into the backup panel and working well.
Had a successful backup power transfer as well. It was right at dark, so I will have to wait until tomorrow to test the solar re-charging the truck even off-grid.
Also tomorrow we are installing the LG battery into the system to see how that goes. As far as I know, there is not anyone else with that tied in.
Ford F-150 Lightning My new Ford Home Integration System + Battery installation project IMG_2064
Ford F-150 Lightning My new Ford Home Integration System + Battery installation project IMG_2065
tearitupsports
Russell
Houston, TX
Next update. I can confirm that excess solar will charge the truck even in off-grid mode with the HIS system. In the M-professional app it even shows power flow animation going into the truck.
Its about as fast as a level 1 charger right now, but is working.
Ford F-150 Lightning My new Ford Home Integration System + Battery installation project IMG_2066
Ford F-150 Lightning My new Ford Home Integration System + Battery installation project IMG_2068
Ford F-150 Lightning My new Ford Home Integration System + Battery installation project IMG_2069
tearitupsports
Russell
Houston, TX
I installed the battery this weekend. I had some issues with the inverter in a loop trying to update the firmware of the battery, but I was able to get that solved.
Now I found out the DC fuses in the inverter were blown. My system has never powered anything so I am quite sure that they were blown long before this battery install.
I have new fuses coming tomorrow and should have the battery up and running.
The inverter sees the battery over communication, and I am getting state of charge, and other stats, so I should be close.
Has anyone else installed the LG (or any) battery in the HIS besides me?
blitzlinger
WNC
'23 F150L Platinum, '18 Toyota 4Runner TRD ORP, Polaris Ranger EV
ISP Owner & Network Engineer
...Now I found out the DC fuses in the inverter were blown. ...
Where are the fuses located in the Delta inverter out of curiosity? Mine worked fine for awhile until one day it didn't, and ever since that day it never worked. I was only aware of the DC fuse in the FCSP, but not the Delta inverter.
tearitupsports
Russell
Houston, TX
Are you referring to the truck or the LG battery. I am referring to the LG battery input connection fuses which are in the Delta inverter. There is a 2 pole fuse holder block.
There are no fuses in the inverter for the truck DC connection.
blitzlinger
WNC
funkatation
2024 F150 Lightning Platinum
How did you acquire the system? When I checked, it appears I can only buy it from SunRun and they require installation. I was quoted 13k, which I think is ridiculous.
tearitupsports
Russell
Houston, TX
I got my system through a private sale from another member here, and installed it myself (with assistance from a friend/master electrician), so my cost risk was as low as possible. I do not recommend purchasing this system yet, until all issues are resolved. I do know they are being worked on. I will be doing full posts on some alternate solutions as well.
I will find out if/where this system could be purchased instead of Sunrun. I will have to see if that is possible.
