Albern
- Jan 28, 2023
- Second star to the right
- 2024 Ford F150 Lightning Platinum; 2015 Chevrolet Volt
Tire sticker on the drivers door jamb.So how can I tell when my vehicle was built? I'm searching vin's but it's not being helpful.
Looks like mine is 4/24, just missed it. Thank you.Tire sticker on the drivers door jamb.
My non-affected truck built June 2022, original scheduled blend day was June 9th 2022, but it was delayed several days
The shudder I had in my truck was definitely due to poorly balanced tires, but some others on the forum have apparently had their tires' balance checked without fixing the shudder. They may want to look at the manufacture dates...On September 12, 2024, Ford received a Global Common Quality Indicator System (GCQIS) incident report pertaining to a missing left front upper control arm ball joint nut on a 2024 model year F-150 BEV vehicle. The customer reported that at 639 miles they experienced intermittent vibration while driving at highway speed before the vehicle suddenly made an uncommanded left turn into a side rail. Upon inspection, the dealer technician discovered the upper control arm nut was missing and the joint had separated from the knuckle
