OTA Software Update 10.1.1 - Enhanced Connectivity and Power Management
PJnc284
Garner, NC
Which veepeak? I use this one for ABRP and CarScanner and haven't had any issues with a Galaxy S22+.
Veepeak OBDCheck BLE Bluetooth OBD II Scanner Auto Diagnostic Scan Tool for iOS & Android, Bluetooth 4.0 Car Check Engine Light Code Reader https://a.co/d/6x3VisH
Warp Asylum
Austin, TX
I plugged in a route and it added EAs, Tesla superchargers, EVGo, etc stops with > 10 min charge times.
Ford F-150 Lightning OTA Software Update 10.1.1 - Enhanced Connectivity and Power Management 1000001790
hiimisaac
Isaac
Eastern, NC
F150 Lightning Lariat (510A)
Software Engineer
What's your Google Maps and Android Auto version number?
hiimisaac
Isaac
Eastern, NC
Software Engineer
Android Auto is the same. Downloaded your version APK and same result. Im gonna pull the 12v for a hard reset and beyond that I'm out of ideas.
10.x.x isnnot a vehicle software version. It’s an Update Number.
There is no truck software version. Each module has a software version. Different trucks are shipped with modules on different versions and/or with different hardware iterations of the module.
Hence not all trucks get every update and all trucks are not updated in a blanket way like a Tesla or iPhone would be.
You can to have someone pull your vehicle module software status with FDRS in order to determine what updates are available for your vehicle.
Jasin
Jasin
2022 Lightning ER Lariat
Appreciate the input.
I have now had 2 people pull my vin from FDRS and I have 13 modules that have updates.
PJnc284
Garner, NC
Post a picture of what you're seeing
Not unusual at all. In two years of ownership and having had it checked a dozen times, I have had between 7 and 15 modules showing available updates. The ones that really need updating get done via OTA or recall (dealer visit required). I've never done them myself.
Don't stress out over it. You are not being singled out. But the only way to truly solve it is to buy the equipment and do the module updates yourself.
Personally, I have had more added features (glare-free lights, BC 1.3, etc.) doing the FORScan mods myself which only require a $60 adapter.
PJnc284
Garner, NC
So just discovered that you apparently can change a charging location if you have multiple charging stops but you have to start the route. Seems like a bit of a miss by google.
https://www.ford.com/support/how-to...se-android-auto-ev-routing-for-ford-vehicles/
Replacing Suggested Charge Stops
Select your destination. A preview of the route displays with suggested charge stops.
Tap the Replace button on the route preview.
Note: If your route has multiple stops listed, the option to replace displays only after you start the route. It is located under the teardrop icon.
Select an alternative charger from the list of chargers along your route.
Tap the Select stop button
awilli1010
SE Michigan
I watch the update threads like hawk, no '22 owners have reported [OTA] 10.x updates, you're in good company with myself and the rest of the inaugural owners.
I got the karaoke update today. Not that I’m interested or complaining but I don’t have the app even the update was successful.
I've read reports that the icon might appear in few hours or the next day.
MJB28
DE
2022 F150 Lightning, 2020 Harley Livewire
I got the update here. 2022 also
It took the second time I started the truck and then the app was there
hiimisaac
Isaac
Eastern, NC
Software Engineer
Do you have an Android and can test routing with it?
Jasin
Jasin
Would the 12V being low prevent the update? Based off someone doing a FDRS pull for me for me my 12V is at like 56%. Then today I started getting the Powering off to save battery messages as soon as I turn off the truck. Do I need to or better yet how do I charge the 12V do I need the external power supply or is there another way?
