Norcati
Dylan
2024 Lightning Platinum
Only if it works...I have an update past where that was supposed to work but it's not working. I'm wondering if the truck is missing a different update in a different module or something that makes that work.
Did you ever figure out a solution to this? I got the truck on a week ago so I could not tell what version it was on, then I got the 10.1.1 update three days ago. Android Auto will not show charge info for me, so I am in the same boat as you.
P-38
2024 Lightning Lariat
I have been unable to find a solution. Ive tried removing one of the 2 Google accounts on my phone (even though it was always connecting to the correct one). I've tried enabling all the Ford services possible on the chance it's tied to one of those. Rebooted phone. Used my wife's phone.
Still running stuck.
Hmm, wondering where this update is stuck at now...
I'm guessing they are working on the error resolution patch first, then update the 10.3.0 code.
Deploy the fix first to affected trucks, then revised 10.3.x to the rest of us.
Keanen
Keanen
MN
2023 F-150 Lightning
Software Engineering
I went to check for updates today, and I am downloading the window fixes, yeah! :)
FLSpartan04
Daryl
23 F150 Lightning XLT ER
Anyone get this update recently? Would like to see faster charging speeds soon.
Keanen
Keanen
MN
I ended up getting BC 1.4 but still not 10.3
muels7
22 F150 Lightning Lariat
I'm getting my Window update tonight. Hopefully that means BC not far behind. Still not on 10.3 either, but BC 1.4 more important to me right now. I have a road trip I want to do, but holding off for nicer weather and hopefully BC.
I believe 10.3.0 is still on hold for retooling and a fix for those negatively affected when it first rolled out.
FLSpartan04
Daryl
Ahh. Ok. I was wondering because I was caught up and just got the window update. A lot of noise was made about the charging speed update, but I have yet to get it. Must just be for the influencers first. Any word on getting the updates from the 24 trucks (let alone the 25 updates)?
This update never reached my truck, plug pulled before general distribution I think.....
No word as to when a stream lined fix and resumption of roll out will be happening.
PJnc284
Garner, NC
No reason they shouldn't have it straight by now. I updated everything in FDRS on mine last October and have been charging at 500 amps since then so a lot of us have had it for a while. The updates are still there in FDRS as I updated a SR last weekend and it was able to charge at 500 amps after.
But those would be individual module updates installed manually, while OTA's are packaged for wide automated installation with no special tools.
Over the past 3 years I've seen several OTA's get cancelled mid deployment never to be seen again.
They repack the goodies in with a newer OTA, could be that the key elements are reaching trucks under a new but less "descriptive" release.
