Priority Update-23-PU1129-CBC-ODP - Powertrain
mrau
23 Lariat⚡ER
Hopefully Ford will update that web page and clearly show it is the Charge level for 12 volt or LVB (Low Voltage Battery).
@Ford Motor Company
It is easy to misunderstand.
We've made suggestions on the FEEDBACK for for the desktop website, who knows when they will perfect the description.
Chriseberle
F150 Lightning SR Tesla Model X
@Ford Motor Company
You were right my apologies. My state of charge is a 94% and 12V is listed at 93% so I got confused.
trev5150
Trev
Pilot of pilotless things
This update is available but won’t go when I try to update now. Says “Interrupted by Another Process”. What could that be? It’s BECM so I tried doing the update without the shore power cable but that didn’t hel.
Dolio
Ryan
Tacoma Region, Washington
youtu.be
2023 Lightning Lariat ER Max Tow Carbonized Gray
if the module/cell variation is too high, as is, my truck will refuse to move but after update, it will be able to limp at lower speed/power to my destination?
Not sure, Mine threw the service now errors before I got the 23B57 update, I believe, and I was still able to drive it at reduced power. But there might be different situations. Probably best to get the update sooner than later. I believe it's more of a case that the update will let it detect a problem earlier than without it. Perhaps without it such a problem could go undetected until the point that it would not allow for a limp home mode? Perhaps someone else has a more comprehensive link to a more precise description?
Maxx
What was the solution to your service now warning? Did you have to replace a module?
Dolio
Ryan
youtu.be
trev5150
Trev
Apparently this update won’t go until I bring the truck in for a recall, which in have scheduled for July.
ScubaSteve_TheReal
Midwest USA
Derivatives
Hope to see this OTA update one day myself.
Only have owned this lightning since March 2024 though. Only thing is my previous lighting was lemoned shortly after dealer manually installed this update last fall. So there is always that concern in the back of my mind. Waiting for OTA and not in a hurry to take this lightning to dealership after what happened to my previous lightning…..
