Pushed charge too close on road trip
ILikeBigMutts
Jeff
2024 F150 Lightning XLT
Rarely take the Lightning on longer trips. Went on a 175-ish interstate mile trip (round trip) and underestimated effect of pulling a trailer. Small, aluminum 4x8 trailer, but it decreased mileage noticably. Florida, nice day in the 80s.
Starting home with 900lbs or so on the trailer, it seemed that all would be OK. I know chargers are plentiful, but I've only done home charging and didn't really want to go through the hassle of public charging. As the miles ticked by, the "miles available" kept trending downward toward the "miles to destination" (home), meeting at 25 miles.
Ford F-150 Lightning Pushed charge too close on road trip 1742231700270-cn
I then began throwing cargo overboard. Turned off AC and fan, even turned off the radio. Reduced speed to around 55-60 (insanely slow on I-95 in south Florida). It worked! A gap started--slowly--opening up with battery miles remaining inching above miles to destination.
Ford F-150 Lightning Pushed charge too close on road trip 1742232006556-f8
Knew there was a charger just off interstate about 3 miles from my house, but I'm feeling lucky (and sweaty).
Ford F-150 Lightning Pushed charge too close on road trip 1742232142731-02
Finally home, with 5 miles remaining!
Ford F-150 Lightning Pushed charge too close on road trip 1742232250894-8a
How accurate is the mileage calculator? I really have no idea since I didn't run out of juice. However, my sense is that it was very close. I could actually watch the calculations move slightly in my favor in 1/10th of a mile increments when I turned off AC, lowered speed, etc.
I was a little surprised at how much of a difference it made when I turned off AC and lowered speed. I think lowering speed resulted in the most improvement.
It was a good thing my wife wasn't with me. She would NOT have appreciated my experiment.
The Lightning is my first EV, and I've for many years driven ICE F150s. Honestly, it's the best vehicle I've ever owned even with range restrictions. It would have been simple to plan for charging that didn't leave me white knuckled. I was just stubborn and curious.
Discwizard70
Michael
F150 Lightning, Mustang Mach E
Vehicle Inspector
Good information here.... Thank you for your experiment!
K6CCC
Glendora, Calif.
2024 Lightning Flash in Antimatter Blue, 2017 Toyota Corolla
Two Way radio systems
The reduced speed was likely the bigger contributing factor to eeking out a little more range.
Strong suggestion, even if you don't NEED to, try out a couple different public charging stations of different types. That way you will learn the good, the bad, and the ugly to using public charging. If you have a NACS adapter so you can use Tesla SuperCharger locations, make sure to include one of those. Some networks are totally plug and charge (including Tesla), and some require either using a credit card or being part of some other network. Learn how to check for availability at stations using either the FordPass app or an app for that network.
B177y
Bill
Northwest of Northwest WA
www.ptcoffee.com
2024 Lightning Pro ER Max Tow
Coffee Roasting
I basically did the same thing as you on my first road trip in my Mach-e. I pulled in to a DCFC with 1% left after ignoring the navigation suggestion to stop earlier. I thought that I was going to make it with 10%, but then I hit some unexpected cold and sleet. I quickly learned to trust the navigation and stop where it told me to stop to DCFC. Now that I have done lots of road trips in both my Mach-e and now the Lightning, DCFC is no hassle at all, and I trust ABRP, Google Maps, and all of the other navigation aids.
gbuydos
Central Iowa
F150 Lightening Flash '24
Good experience and thanks for sharing. I don't take mine on road trips, I am driving mostly backcountry roads. I rent a F150 ICE if I have to pull my trailer go outside a safety range. An F150 ICE has a 26 gallon tank and good for up to 500 plus miles.
Firn
23 Pro ER
Nice writeup.
I have to pick on you though, one bathroom stop at a DCFC and you could have driven with the AC on and at a normal speed.
I suggest just trying it (DCFC). There have been instances where I had to charge when I had no expectations that on that day I would need to. White knucking it just isn't worth it when all that anxiety goes away with one decently timed stop to grab a snack, go to the bathroom, eat lunch, etc. It's actually much nicer than getting gas, it's just the apps (if needed) that are annoying.
ILikeBigMutts
Jeff
I'm going to take the good advice offered and do a couple of public charges just for the experience of it. While I've only ever needed to charge at home, I'm sure there will be a need at some point. Solid thoughts on not wanting to "learn" about charging, apps, etc. when I'm in a bind. Thank you all!
