For DC itโs the opposite, the truck tells the charger it wants 500A and the EA charger laughs and says youโre lucky to get 100.Oops. I knew that, I don't know why I got it backwards in my post.
What does the charging curve in the app look like? Has it ever gone over 3.7kW? That will show you the voltage and current measured in the Autel unit.The app and the selector switch in the charger are both set to 48.
Thanks for the update!In case a similar issue happens to anyone else, here is an update and how the issue was resolved by Ford:
On 9/13, I had a service appointment at my local Ford dealer to troubleshoot the issue. They performed tests on the battery packs and the related systems and the truck was diagnosed to have a faulty secondary onboard diagnostic module (SOBDM). It took them a week to get the part and perform the replacement. I received the truck back on 9/20 and so far so good (fingers crossed). I can now charge at home with my level 2 Autel charger and it is performing correctly.
When I first tried to charge the truck on a level 2 charger, the truck faulted and the wrench icon appeared on the dash. When I tried it again, it faulted again, but no wrench. When I called the dealer, while on the phone with the service advisor, he was able to remotely see the codes the truck was throwing. From there, we scheduled the service with a hunch that the truck was having an issue with the AC charging, especially since I was able to use DCFC to charge. If it would help to show what the technician did to diagnose, let me know and I'll be happy to post it here.Thanks kcoates2. How did they diagnose it? Did you have any error or service lights on your dash indicating a problem?
I ask because I just got my truck back after they replaced an array due to a faulty cell and I immediately experienced a similar issue as you, but with with my Ford Charge Station Pro. I could once charge close to 10% an hour, however it recently took me 9 hours to charge just 18%. DC charging seems to work just fine though.
I look forward to your response as it might help provide some guidance for the crew at my dealership.
