PreservedSwine
Fort Myers
2023 Lightning
“UL Certified” is meaningless. It must be listed to a standard and be given a listing number.
I could be wrong, and it’s been a while since I’ve dealt with UL, but I thought receiving UL certification required a listing number be given with the certificate?
At any rate, I see the extension plug being exponentially more dangerous than the plug alone. (Not saying I’m against them, a .0000001 fail rate might increase to a whopping .000001, an increase of 10x yet still insignificant).
That’s a metric crapload of current being delivered, and under optimal conditions no one would be using any plug-in connectors of any kind. But as the plugs are a necessity, the temps are monitored with the cable and harness system in place. With the extension cable, you not only lose temp monitoring, you’re also adding (2) more weak point of contacts.
The fail rate will still be infinitesimally small, but the failures that manifest could be catastrophic. How many are “acceptable” for the sake of convenience? Beats me, I’ll leave that for the actuaries. I suspect time will tell.
Ramik
Ryan
New England
2023 Lightning XLT
Internet Service Provider
If A2Z sells it, I’ll buy it. My experience with their products is 10000% and their support is so good.
I trust they are taking safety seriously. Their interviews with @tommolog, their CEO and their contract engineer about the NACs to CCS adapter were impressive. Fanboy? Yeah maybe, but I think whatever they sell will be safe. 🤷🏻‍♂️
hajalie24
2024 F-150 Lightning Lariat Antimatter Blue
Hopefully all the negativity results in the price lowering for this.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Even if I thought it was safe (I don’t) I wouldn’t spend any money on it. I haven’t had any problem charging at Superchargers with the short cables. If Tesla doesn’t want me to take up two spaces they can add longer cables.
The Weatherman
South Central KY
My concern over access isn’t what TESLA thinks, it’s what that TESLA driver with an attitude thinks. We’ve seen several comments about individuals making noise over this issue even when there are other chargers available.
In the current times we are living in, it seems it’s becoming more common to shoot first and ask questions later. 🙁
UL does not use the term “certified”. An item can either be “listed” to a standard, or “recognized”.
”Recognized” only means that it is a component than can be used in a listed assembly. If you buy a recognized component it doesn’t mean that UL has evaluated it the way you intend to use it or the way the seller says you can use it.
I won’t comment regarding any of the FUD spewed forth in this thread.
Ratherhavefun
Socal
2022 Lightning Lariat
CEO of Seemore and Dolittle
That NACS adapter gets pretty hot and that’s with the truck taking in less than 180kW at peak and most of the charge curve being a good bit lower. Adding the extra resistance and bulk of an extension cable just seems like a bad idea. Tesla just needs longer cables on their charger, which the newer V4 pedestals do have…. But it seems even with that, we still have to straddle spaces for the cable to work for the Lightning.
Show them Tesla’s own guidance on how to straddle spaces to charge your non-Tesla EV. I showed a lady that the first time I tested my NACS adapter. First she was going to tell me that I can’t charge there, Tesla only, it won’t work…. Then I explained to her that Tesla opened up to Ford, Rivian and soon others and showed her it was charging. Showed her Tesla’s info on how to straddle spaces. She commented on how Ford was stupid for not putting the charge port in the right spot, but was otherwise receptive.
She’s kinda right… wouldn’t it have been intelligent if Ford followed Tesla’s lead in charge door locations, that’s all I’m sayin’!
potato
BC, Canada
2023 F150 Lightning XLT ER
Then you would be guaranteed to have to unhook your trailer at all charge stations that aren't pull-through, which is most of them. There are pros and cons to everything.
Ratherhavefun
Socal
Normally, I don’t rebut, but I think your reply needs a rebuttal.
You’re correct 🥔! There are plenty of pros and cons to everything…! And I absolutely love my Lightning, so I’m not a hater!
Maybe consider it being a badge of honor for having to charge while your trailer is behind you???
I too pull trailers and certainly don’t like inconveniences, but maybe Ford should have thought several things through more carefully… touché!
And only a guess, but I betcha Ford had thought about snuggling up to the Tesla charging network long before the first Lightning prototypes were on the proven grounds! Not everyone can be pleased all the time.
You win if that’s what you’re after!
His point is a valid issue, there is no need to be a jerk in your response.
Ratherhavefun
Socal
response.
You’re funny… Have a look in your mirror and tell everyone that you’re not being a jerk! What a bunch of crybabies! Grow up!
