Unable to charge v4 Superchargers
Jack's F-150
2023 F-150 Lightning
Just charged using my A2Z adapter at the Mcclenny V4 chargers, the magic dock would not work, but had no issues charging my F150 Lightning ER with A2Z adapter. I live nearby so reach out if you have any questions about this charging station.
-Thomas
potato
BC, Canada
2023 F150 Lightning XLT ER
-Thomas
Good info, thanks.
But it sounds like OP knows what he's doing with charging, and this thread was more of a heads up that even Tesla's well known reliability is not 100%. Some temporary issue made him unable to charge at a station that should have worked. Always have a plan B.
tnugentfl
palm coast, fl
2023 f150 lightning lariat ext range
I'm really glad to here it was functional. It is nice to see the infrastructure expanding, and there almost always a secondary option where I travel. Really nice to have so many Circle K and Pilot stations coming online.
Icruz101
Isaac
Waco, TX
Most new v4 sites won't dispense the Magic Dock any more.
Not true, instructions state you have to hold the button for 5 seconds. I did that and it releases, but I still get a charge fault.
Icruz101
Isaac
Waco, TX
V3 and V4 is not part of the equation: only TESLA decides 'which' locations are available for "NACS Compatible" other EVs, like ours... it matters not whether V3 or V4...
V4 units are 'built' with the Magic-dock adapter built in, but that is ONLY for future usage, if deployed, by TESLA. It has no bearing on whether 'we' can use these locations, or not.
The ONLY way to know if you can use ANY Tesla Location is to check with TESLA, and the Tesla MAP, with the ONLY Filter used for 'Nacs Compatible'...
'Other EVs' filter will also work, as they have the Magic-Dock adapters available... well, at least most of the units - the other week in west Atlanta, that location had at least 3 that had been stolen from the unit.
The Buc-ees in TX have V3 & V4’s but thus far, I’m only able to access the V3’s.
Icruz101
Isaac
Waco, TX
I had this issue with Plugshare. A V4 install in Easton MD showed as being available to non-tesla vehicles, but it wouldn't show up in the tesla app when I tried to activate the chargers. The Magic dock would pop out, but the truck wouldn't charge at all. It's possible that they have since activated it, as someone since did have a successful charge, but a couple of months ago when I tried it wouldn't work.
Had the same issue with the Tesla app and though it said V4’s were available, I was forced to utilize the V3’s. This on multiple occasions tots past few months. V4’s were online in September.
You obviously are welcome to disregard what I am saying but I'm just trying to spread a friendly warning. I am highly seasoned in this area and it is clear to me there is an issue with some new v4 installations, listed as accessible, and our trucks.
when you use the term 'our trucks', you also obviously are welcome to disregard what anyone else who is successful in charging at Superchargers might say : it's 'obviously' not 'out trucks' that are of concern, only yours. The rest of us are very 'seasoned' in these areas, too. V4s are not accessible.
tnugentfl
palm coast, fl
sure thing, lol
astrand1
Alex
Studio truck driver
So low and behold some of the A2Z typhoon pro adapters have a connection pin issue that makes them not work on v4 Superchargers
Is there a way we can figure out which adapters have the issue? I have the pro adapter form A2Z but have not used a V4 only V3.
Icruz101
Isaac
Waco, TX
Has your Tesla adapter arrived? If not it should be soon, I received my adapter in Dec when I gave up hope.
How did you figure this out? Just curious.
On the Road with Ralph
Ralph
Mojave Desert, California
2023 Ford Lightning Pro
Real estate/biz consultant
I had multiple faults at v4 dispensers at a new Tesla station in Williams, AZ using an A2Z Typhoon Pro adapter. The station is clearly marked as as open to non-Tesla vehicles on the Tesla app. I was able to initiate a charge, but it immediately faulted out. Rather sheepishly, I ended up at the nearby EA station to finally get a charge. I normally have no problem with v3 Tesla dispensers.
tnugentfl
palm coast, fl
You should contact A2Z, sounds like you have the short pin issue as well
