Monkey
- Dec 9, 2022
- Somewhere in the mountains
- '23 Lightning, Tesla Model Y, and more...
- Occupation
- Semi-retired electrical/computer/software engineer
No leak, perfectly normal, which surprised me the first go around. Both our Model X and now our Model Y have done this. It will vent if given enough pressure. I have only had it happen twice on the X, once on the Y. Happened when supercharging and all three times the outside temp was rather cold -- like -7F and colder. We're also at altitude which makes the vapor/boil point of the coolant (and water and everything else) lower. And yes, the cooling system on these cars do have pressure release vents. They're required to have them. Service tech even showed me a picture of one on our Model X because I promptly took it in for service the first time this happened.Teslas are *not* supposed to do that. Are you sure you don't have a pinhole leak in one of the radiators?
Our Model X went away a bit over a year ago... Model Y has almost 50K miles on it and was recently in for a check-up and to address a few things. I raised the issue with them again, all normal and it's usually a charging in extreme cold weather thing. High altitude makes it even more likely. But under more reasonable temperatures, it should not happen unless the battery is overheating and driver should be getting warnings in that situation. Pressure and coolant test all came out normal and they're not recommending the coolant flush for the 3/Y at 50K miles anymore, now saying better at 5 to 6 year or 75K miles.
Yeah, I get it... I've seen enough reports of crappy Tesla service people. Met one or two myself over the past 7 years of owning a Tesla.Moral of the story: I wouldn't trust Tesla to give you the straight dope about this kind of problem on their own cars, and definitely wouldn't analogize it to a Ford...
