Won’t charge up to 300+ miles
I'm going through that now. I drove around 60 miles today, mainly on 55 mph highways achieving around 1.5 to 1.6 mpk. Returned home and charged to 80% and ended with 161 miles to empty.
After some calculations, that came out to be pretty accurate. 80% of 131 = 104.8 kwh.
Multiple that by 1.5 & 1.6 comes to 157.2 &
167.68 miles to empty.
If your DTE is still accurate, you must not have got the update yet that "fixes" it.
deserthi
Larry
San Antonio, Tx
2023 Ford Lightning Lariat
Tech
I see plenty of people on youtube charging their extended battery 320 to 326 miles. I only have 9K miles and have never been able to charge to 305 miles. I know it is only a guess o meter but when you see a number charging to over 320 miles and you can't even after resetting the thing, something is wrong.
Randall Stephens
Seattle
2023 F150 Lightning Lariat ER
Jet Builder
What is your miles per kWh?
Just confirming, did you reset the following?
Settings > Vehicle > Vehicle Driving History
TheBigBezo
Earth
F-150 Lightning Lariat ER
I wouldn't worry about a 'range' and instead focus on your current efficiency for whatever driving you're doing. With a few exceptions, the actual capacity of your battery has not changed. But to your question, I have seen my GoM show as high as 370 and I have achieved greater than that from a full charge tracking it on my odometer.
This is a recent example from 2/29 pre departure with fully conditioned battery at 100% preparing for the Jersey road trip. I had not reset my vehicle driving history and won't until 3/31 after I pull my winter quarterly performance data, I'm not certain I'm shooting myself in the foot by resetting it, ie. the history might have the ability to run a full driving season and the time & temp factoring with my driving style would be lost erasing it quarterly. I'll try and remember to post a snap shot at the end of the month.
Ford F-150 Lightning Won’t charge up to 300+ miles 1710007277304
F150ROD
U.S. Navy Retired
I curse this thread, I want my accurate range numbers back.
ytwytw
Toronto, Canada
2023 F150 Lighting ER Lariat
this is actually the correct answer.
Once charged to 100%, it will always show you over 300mi range, the reset will clear out calculations based on temperature and recent history
deserthi
Larry
San Antonio, Tx
Tech
Oh yes, a few times. I am slow charging now and am at 93% with 286 miles showing. Thats 304 Miles at 100%. It's like this every time???
Grease Lightning
Johnathan
Albany, Oregon USA
2023 F-150 Lightning XLT
Are you actually charging to 100% or just extrapolating what 100% should be?
I ask because I have noticed when I do charge to 100% to balance the cells, those last 1-2% on the meter makes a huge huge difference, then from car scanner it appears Ford plays a little magic as 100% is more like 102% as it deep charges into a buffer zone a little when balancing.
My math, 307.5268817204301
PreservedSwine
Fort Myers
2023 Lightning
It’s not that you can’t charge to 300 miles. It’s that you can’t charge to a 300 mile estimate, which is a completely different thing.
You’d think the two would have a lot in common, but in reality, that’s not true most of the time. I can lose 20 or 30 miles of estimated range simply by hopping on the interstate on my way home for 10 minutes, instead of the city roads I usually take.
The next day *POOF* I’ve “lost” 30 miles of range.
But what have I really lost?
Nothing
