Borgelpe
- Oct 25, 2021
- South Florida
- 2021 Raptor
- Occupation
- Aerospace Exec
How about Auto global windows up on auto rain sensor detecting rain?
Some Mercedes models do this. A convertible will even put the top up.How about Auto global windows up on auto rain sensor detecting rain?
I'm having the same issue. Did you get it resolved?I am getting a "service procedure has been interrupted" error when trying to write the window open/close mod. Only on the DDM & PDM; BCM & APIM worked fine.
Any ideas what causes this error or how to resolve?
EDIT: I think I found the answer on one of your other posts - need to use a version newer than what's currently released.
https://www.f150forum.com/f129/forscan-14th-gen-f150s-481816/index52/#post6948351
Check to make sure you are on latest versionI'm having the same issue. Did you get it resolved?
DDM 740-06-02 xxxx xxxx 01--Check to make sure you are on latest version
Leave the dashes, only change the number values that are different. Ex: 01DDM 740-06-02 xxxx xxxx 01--
PDM 741-06-02 xxxx xxxx 01--
DDM 740-06-03 01xx xxxx xx--
PDM 741-06-03 01xx xxxx xx--
BCM 726-11-02 xx01 xx01 xx--
BCM 726-22-01 xxxx xxxx 01--
BCM 726-22-02 xxxx xxxx 01--
I'm on 2.3.43 release, 2021-09-28
Do the -- mean leave the numbers as is or delete what's there? I know that the x means leave what's there.
Worked like a charm, thank you!Try this in BdyCM: 726-10-01 xx00 xxxx xx--
I'm surprised that the Forscan reset didn't work for you, but here are 2 methods that some have claimed resets adaptive learning :Hello @Livnitup is there a proper way to reset transmission adaptive tables? I did the reset transmission option via Forscan but tranny is still jerky. Is there more than one module that needs to be reset?
I find that my tranny gets jerky after driving 4-5k miles gently and hypermiling i.e., lots of coasting in electric and gas motor stopping and starting. I reset tranny via forscan once about 5k miles ago and it made tranny smooth again, but its gotten jerky again. This time, the forscan reset didn't seem to cure it so I was wondering if there is a more definitive way to do it.Resetting it will make it jerky until it relearns
Just realized I had omitted the 740/741-06-03 values below on the Global Open/Close on the spreadsheet so it's been corrected and these are the values:
i’ve tryed these codes but not luck bcm codes don’t stayJust realized I had omitted the 740/741-06-03 values below on the Global Open/Close on the spreadsheet so it's been corrected and these are the values:
