Ron in Oregon
- First Name
- Ron
- Sep 22, 2021
- Eugene, Oregon
- 2021 F 150 hybrid
- Occupation
- retired
Nice job! I would like to do this for our trailer. Reading another owner's project, he put in a 'transfer switch' , providing an automatic switch between the shore power OR Powerboost cable. I would appreciate if you could provide part numbers and sources for your cables and connectors. Thanks!When we wash and winterize our trailer in a week or two I'll take some pictures for you. The shore power inlet is at the rear-quarter on the drivers side. However, I have bypassed the trailer's as-built shore power inlet completely. The AC breaker panel (& DC fuse panel) are underneath the stove/oven midway on the passenger side. From the yellow connector on the trailer tongue (see pictures in my OP) the power cord runs along the frame and up the same hole as the propane line to the stove. All I had to do was gouge out some spray in foam sealer and push the cable up along the propane line, then spray in some new foam crack sealer. I disconnected the as-built shore power line from the AC breaker box and connected my new cable in it's place. If we are at an RV park we now run the power cord from the RV park pedestal to the yellow connector on the tongue of the trailer.
The PPoB will run the AC just fine - it has plenty of juice! However, being our only outing with this new setup was just last week and we are in the Pacific NW there was no need for the AC this time around. As you can see in the last photo in my OP we were feeding the trailer 1300 watts (battery charger & fridge) while running down the road - which still leaves 2300 watts available!
I think I'm going to name the truck PowerBeast! ?
-Eric
