smarty39
Kyle
Alberta, Canada
2021 F150 Velocity Blue Lariat Sport
Amazing, thank you!!
Hectort713
Hector
Houston, Tx
2021 Ford F-150 Tremor
Thanks for pointing that out... The release I'll be releasing later today will show correctly and will also allow you to use metric but set the tire pressure as PSI
If you tap on the script, then you to widget settings, tap on measurement units, you will see imperial.
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) 418370F3-D79C-4764-AFF1-A078E17271BF
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) F2CFB8BD-3BDB-4120-BA25-FEE076B7DE04
Hectort713
Hector
Houston, Tx
This is amazing, thank you so much for the effort!
The only thing in noticed in mine is that the tire pressures show up wrong. I am using the ā€˜METRICā€™ option though so maybe itā€™s something messed up with that portion of the coding? Everything else appears correct.
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) 00201BD3-5FB3-4017-8817-1308DBFA3F3F
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) 3AB08797-9752-45A2-B0EB-5881365BC25A
JediNut
Emmett
Rocklin, CA
'21 Ford F-150, '05 Harley Davidson Softail Deuce
Iā€™m having the same issue where the formatting is a little different. It only shows two of the tire pressures and the oil life doesnā€™t show up. Not a huge deal and might have something to do with different phone screen resolutions?
I wasn't complaining about the formatting at all... I was honestly saying how awesome it is! :)
Is the hood status available? I know that I get SecuriAlerts when it's opened. I really wish I knew JS better and I could try contributing the configuration of a large widget layout (4x4)... I would be more than happy with having an entire page on my phone for @tonseto7's widget plus other truck related icons. :-D
Icecoldak
Steve
Alaska
2019 F-150 Limited
I wish I could get mine to work lol--Keep getting the Error!
RedTXV
2021 SQ Limited
Admittedly I have no idea what I'm doing here, but I'm getting this message when trying to add the script. This was after I copy and pasted it all.
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) IMG_6231
ZWARRIOR
2021 Ford F-150 Lariat 501A 2.7l
Software Engineer
Dude I didnt even know Scriptable was a thing! This is awesome. Thank you so much for bringing this forward, I already forked you thing, I will play with it some more after work. I did take the time to do this hehe
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) Ford Scriptable
Icecoldak
Steve
Alaska
2019 F-150 Limited
I finally got it to work :) I was getting the code from my computer then paste/copy email to me and then do it from my phone! THIS time I did it all on my phone and it worked 1st time! Anyway why Im I getting XXXX for all my windows?
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) IMG_0295.PNG
Hectort713
Hector
Houston, Tx
You probably didnā€™t copy and paste everything correctly, because youā€™re also only getting 2 TPMS
Icecoldak
Steve
Alaska
2019 F-150 Limited
I just did it twice more copied from top to bottom including the last part with lots of ************************** haha! same thing
ZWARRIOR
Software Engineer
Are the windows opened? if not try to open and close them again turn the ignition on and give it like 10 minutes?
blind56
Alberta
2021 F-150 2.7EB, 2016 WRX
I've also got the left door error. Also got an email from Ford saying my account is locked out a couple minutes after trying this...
