smarty39
- First Name
- Kyle
- Aug 23, 2021
- Alberta, Canada
- 2021 F150 Velocity Blue Lariat Sport
Amazing, thank you!!
If you tap on the script, then you to widget settings, tap on measurement units, you will see imperial.Thanks for pointing that out... The release I'll be releasing later today will show correctly and will also allow you to use metric but set the tire pressure as PSI
If you tap on the script, then you to widget settings, tap on measurement units, you will see imperial.This is amazing, thank you so much for the effort!
The only thing in noticed in mine is that the tire pressures show up wrong. I am using the āMETRICā option though so maybe itās something messed up with that portion of the coding? Everything else appears correct.
I wasn't complaining about the formatting at all... I was honestly saying how awesome it is!Iām having the same issue where the formatting is a little different. It only shows two of the tire pressures and the oil life doesnāt show up. Not a huge deal and might have something to do with different phone screen resolutions?
IT does show Distance to Empty though thats a good work aroundfuel shows -6% but love this widget
You probably didnāt copy and paste everything correctly, because youāre also only getting 2 TPMSI finally got it to work I was getting the code from my computer then paste/copy email to me and then do it from my phone! THIS time I did it all on my phone and it worked 1st time! Anyway why Im I getting XXXX for all my windows?
I just did it twice more copied from top to bottom including the last part with lots of ************************** haha! same thingYou probably didnāt copy and paste everything correctly, because youāre also only getting 2 TPMS
Are the windows opened? if not try to open and close them again turn the ignition on and give it like 10 minutes?I just did it twice more copied from top to bottom including the last part with lots of ************************** haha! same thing
