antho
- First Name
- Anthony
- Sep 20, 2021
- Houston, Texas
- 2021 801A Raptor
This is likely APIM, IPC, and ABS changes but it looks like the Tremor has additional ABS addresses that a '21 or 21.5 doesn't have and it has "Enhanced Memory" as default where my ABS doesn't so I'm skeptical of getting it to work. However, if you're wanting to try and have backups then I would try the following:
APIM 7D0-02-01 xxx7 xxxx xx-- reset APIM after this change
IPC 720-10-01 xxxC xxxx xx--
IPC 720-07-02 x7xx xx--
ABS 760-04-01 xxxx xxx1 x1--
EDIT: Just tried this in my truck and got the Trail Turn Assist slider to appear in Sync but couldn't turn it on so I suspect there's something else going on with ABS version/values
@Livnitup Did you have your truck in 4hi or 4lo when trying?
