Adding Co-Pilot Assist 2.0 with Forscan?
Jesse-Infotainment
2024 F150 Lightning Flash
Looking deeper it looks like the front bliss is NOT needed.
Jesse-Infotainment
They are for the Intersection assist that comes with co pilot360 assist 2.0
Ok, I was trying to make sure for him wanting just the adaptive cruise and lane centering so that was what I was answering. Thank you for clarifying what they are for
superfordman
Troy
NE CO
2021 F150 Lariat
Awesome, thanks for the clarification, I sorta figured it had to be something along the lines as the rear bliss system since its the same sensors.
juicepower
Dan
atlanta ga
2021 F150 XL STX 4x4 VELOCITY BLUE
Integration Engineer
Super informative since I also have a XL STX trim. Looking to add adaptive cruise so maybe this isnt as difficult as I thought. A huge thanks to everyone here!
dre276
andre
NJ
2018 F150XLT, 2021 F150 XLT 302A Lead Foot
could anyone who has successfully completed this do a DIY write up?:)
superfordman
Troy
NE CO
2021 F150 Lariat
@Jesse-Infotainment is there anything special you need to do for the PMI for the CCM? Sounds like the only values stored in it is the VIN. My plan was to just program my VIN into my CCM for forscan and hopefully that's all I need.
Got my new-to-me bumper the other day so going to try some things out tomorrow if I can. If you can share what values you changed to enable yours that would be awesome. Figures crossed it goes as smooth as yours to at least get everything communicating and showing up like it should.
Omodan
Randal
Augusta GA
2021 F150 King Ranch, 2019 Expedition Limited
I have a 2021 King Ranch with 601A, which includes the Ford Copilot 360 Assist 2.0, and can confirm that my truck does not have the front BLISS sensors. The attached picture shows that i have the front BLISS bracket but i dont have the actual sensor.
Reading this post, i was curious what they are for. I recently added the four front proximity sensors and have been wondering what i need to update to get the truck to recognize them.
Ford F-150 Lightning Adding Co-Pilot Assist 2.0 with Forscan? 4332A986-D32F-4B36-8AD9-894165B1D803
superfordman
Troy
NE CO
2021 F150 Lariat
@Jesse-Infotainment update on my progress thus far, unfortunately haven't had as good of luck adding ACC as you did so far. Got the CCM mounted and plugged in this weekend, that was actually really easy on my truck as like I found before, all the wiring was there from the bumper harness connector to the IPMA.
However I can't seem to communicate with the CCM at all and it doesn't show up as a module in Forscan at the moment. I have 12V and CAN voltage out at the CCM connector so I know it's hooked up all the way to the IPMA. I did get my CCM second hand and it's a little banged up so I wonder if it might be a paper weight. I even tried hooking up my advanced IPMA I have and same story. My neighbor just got a 402A to hopefully I can do some swapnostics with his.
Things did get pretty wonky when I did hook up that advanced IPMA as that came from a platinum with 360 cams, etc. So far on either IPMA when I have everything enabled I think I need, I get all the options to ACC and even IACC, but getting a pre collision warning not available when I turn too much on, so hopefully having the CCM online will sort most of that out.
Can you post or message me what Forscan changes you made to enable your ACC and everything? Just want to make sure I'm not missing something obvious as it seems quite a few addresses need to be changed across multiple modules. TIA
superfordman
Troy
NE CO
2021 F150 Lariat
My 501A is exactly the same like yours, wired for the front bliss sensors but no sensor.
Jesse-Infotainment
Hi, the changes are really needed for the module to be seen.. If it is there it will be seen. The problem I think you are having is even thought the plug was there the wires may not go all the way to the IPMA.. You need to verify the wires are populated in the plug I attached.
If the module is not seen in Forscan you need to delete all your profiles and rescan anytimee you add a module and select the existing profile it doesnt scan for new modules.
superfordman
Troy
NE CO
2021 F150 Lariat
My wires are populated all the way out to the CCM connector, as I'm getting 12V power and both CAN+/- voltage like I said at the C1897 connector. And like you said if these wires go straight to the IPMA, there shouldn't be anything else feeding those voltages that I'm aware of from another module/source.
Every time I've been connecting with Forscan recently I always read from scratch and don't select a profile. I'll try clearing out my current profiles again and see if that helps at all but I won't hold my breath.
From there it's either #1 a bad CCM or #2 I still don't have everything enabled correctly for the IPMA to see the CCM correctly and communicate with it.
Ford F-150 Lightning Adding Co-Pilot Assist 2.0 with Forscan? 1646156114354
Jesse-Infotainment
Doesnt need to be enable to be seen in forscan
superfordman
Troy
NE CO
2021 F150 Lariat
Thanks, that's what I figured. I bit the bullet and went ahead and ordered a new CCM as I'm pretty sure my bargain one is toast. So hopefully will have it by the weekend to play around with. After playing with it today, I thought it would work as an IPMA code meaning stating a short with the CCM was active until I got it all plugged in, then I got it to go away after plugging it all in. However today the same code seemed to come and go randomly at times when I would read the DTCs, so pretty sure it's no good.
Jesse-Infotainment
Sorry to hear that. Hope you get it resolved.. When you get it in and working et me know then we can take a look at the programming
