MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
Can someone explain to me what auto seat temp actually does? I dont get what the purpose of this is.
it adjusts the heater and cooled seats to align the set HVAC temp. If HVAC is raising the temp, the heated seats come on varying the intensity to align. If the HVAC is lowering the temp, the cooled seats come on to align.
MikeYQM
Moncton NB Canada
So what have you done differently this time that it worked ? Did you use VCX Nano or ODBEx ?
i used the VCX Nano but I did a new profile when first connecting.
johnatuckeriii
Houston
2021 F-150 FX4 SuperCrew AMB
Hey guys... just wanted to chime in on the auto seat settings... ForScan will absolutely not take my settings for the Auto Seats; I was able to program in the prompt but "Service Interrupted" every time. OBDLink EX and VCX Nano and multiple new profiles as well as changing baud rates and latency.
I noticed @MikeYQM has a heated steering wheel... maybe my 500A just isn't fancy enough? :D
Ruffiano99
Joe
NY
2021 f150
I used the vcx nano to do the auto seats yesterday. Worked with no issues. I have a job 1 platinum with no sync updates. … guess that still makes me a loser… lol jp
ROBB1
Justin
NC
2021 F150 Tremor
Are you running the most current version of forscan?
Platinum Peasant
West Sacramento
I see options in forscan to enable the front and rear cameras for rock crawl mode, which I assumed were already working since I have rock crawl mode. Switched into the mode today and the cameras don’t work, they just default to the standard 360+ rear view. Any one else have rock crawl mode with no working cameras?
MikeYQM
Moncton NB Canada
did you click ‘no’ when you first connected the vehicle to ForScan and the box popped up for the profile?
johnatuckeriii
Houston
Hey guys... tried the "no" when opening Forscan too... version .46 (latest downloaded yesterday).
johnatuckeriii
Houston
Also to add; not having issues writing to any other module. Went through and deleted profiles again. I still wonder if the heated steering wheel has something to do with it... maybe someone else with a lower tier Tremor or Lariat can test (that does not have a heated wheel)?
ROBB1
Justin
NC
2021 F150 Tremor
I activated the rock crawl front and rear camera views with forscan awhile back. They add an additional soft key that looks like a wheel / tire to the other available views. It just results in a blue screen when selected. Best I can tell these views are for the Bronco and display the front or rear tires. Our cameras seem to be incompatible.
Ruffiano99
Joe
NY
2021 f150
Anyone figure out how to get the moonroof to open/close too with the global windows?
Platinum Peasant
West Sacramento
Do you remember what you changed to get front and rear full screen cameras to work during rock crawl?
ROBB1
Justin
NC
2021 F150 Tremor
The ”Bronco“ rock crawl tire view that do not work (no image just a blue screen) was:
IPMA
706-02-02 xxxx Fxxx xx— (OEM was C)
APIM
7D0–01-02 xx03 xxxx xx— (OEM was 00)
Factory my Tremor shows the front camera full view when the drive mode is changed to rock crawl, I can select rear or 360. No changes were necessary to get that in the Tremor.
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
IPMA
APIM
Will these changes works with Lariat 502a package?
