- First Name
- William
- Jan 8, 2022
- rural Georgia
- 22 LIGHTNING PRO IcedBlueSilver 8/23/2022
- Occupation
- Owner
in the RVing industry, there are manufacturers installing electrical 'shedding' devices - which control whether a particular device(circuit) can be powered if amperage usage becomes too high within the main panel. An example is shutting down the power to the breaker(circuit) for the rear a/c unit, or the breaker(circuit) for the electric fireplace heater, etc. This happens on a 'circuit' basis, not just for a individual device or appliance. It's typically for 50amp 240v RVs when using a much more limiting 30amp 120v campground outlet.
I'm not aware of anything, though, to 'dial down' any specific device, as that would be at the device level, not from the the panel. Your 'device', in this case the EVSE charging device, would have to be able to 'read' the amperage level running thru the home's main breakers at the panel. That would be a much more complicated process, with return wiring back and forth between the two, etc.
The other option would be to use a 'shedding' device to shut down certain circuits within the HOME if the charging pushes the main panel's breaker total too high, such as the 240v 30amp water heater, or similar 'high draw' appliance, that operates behind-the-scenes.
