nicholsbradley
Thank you and its been too the dealer multiple times and they do nothing I guess.You got alot to update:
Honestly no surprise on that. After the struggle I've had just to get to the Power Up 2.1 equivalent I have no doubt they can't or wont spend that time on it. I've easily spent 16 hours in the drivers seat f*cking with this and I'm still battling to get up to Power Up 2.3 equivalent.Thank you and its been too the dealer multiple times and they do nothing I guess.
I just noticed you were in Houston as am I around city Center. I have some recalls being done Friday and me and Mac Haik Ford going to have a conversation.Honestly no surprise on that. After the struggle I've had just to get to the Power Up 2.1 equivalent I have no doubt they can't or wont spend that time on it. I've easily spent 16 hours in the drivers seat f*cking with this and I'm still battling to get up to Power Up 2.3 equivalent.
Good luck, Sterling McCall is my dealership, even though I live in Katy.I just noticed you were in Houston as am I around city Center. I have some recalls being done Friday and me and Mac Haik Ford going to have a conversation.
Soo basically I said screw it and was just going to let my license expire and leave the usb in. Had to run to the store quick and ill be damn if the update didn't trigger again. I had to wait in the parking lot at the store for a few minutes to get the restart. Went inside and set a timer for 15. Grabbed what I needed and headed out. Bam update completed. Thank you to everyone for the help. And yes just wait for it (1.7.1). Hopefully you get lucky and it happens sooner than later.You have a chance on screwing it up just doing the updates so does it matter? PMI is easy, you'll be tricking it into thinking you replaced the module when in fact you didn't. Just follow the prompts as if you did replace it.
Remember, you're doing this at your own risk!
Not too bad. Do the Gateway (GWM) first and leave the IPC last.Hiya fellas, my VXC should be here in a few days, can someone check my VIN to see what adventures lay before me, TIA
1FTFW1E85MFB79913
@tonesto7My truck hasn't checked in with Ford for over 10 hours.
The welcome lighting and running boards aren't reacting when I walk up.
I'm not sure what's going on. I don't have any DTCs on any modules so It seems like the IPC update didn't create any errors.
I've already been through the update and although I see this under the STRATEGY folder: ML3T-14C579-AH there's no file extension and it's 194KB in size... it matches as to what FDRS states is the latest Software P/N for the SCCMCan anyone with a Job1 that is showing the SCCM update try to track down the VBF files and PM them to me?
I will flash them with Forscan or UCDS
The files are all stored in "C:\ProgramData\Ford Motor Company\FRDS\frds\data\vehicle_software"
you will need to determine which files are for the SCCM
