ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
I tried enabling camera on speed, but I didn't get 360 degree camera beside the bed camera. Only bed, hitch and rear view cameras working.
Any help will be appreciated to enable the 360 camera as shown in the previous threads.
superfordman
Troy
NE CO
2021 F150 Lariat
I cannot find the Power Steering Control Module in Forscan. How can I open it up?
Mine doesn't populate either.
Looks like you both have MY22 trucks so I imagine Forscan doesn't have these newer calibration files loaded for this module in particular. Send a log to them and I bet they can get it added.
ENG430
Ahmad
Kuwait
Any Idea?
Mine SYNC4 v4.0.21136
Jesse-Infotainment
2024 F150 Lightning Flash
Any Idea?
That is a job 2 APIM software level. You should have cams from the factory. Send me your Vin or look at your build date
ENG430
Ahmad
Kuwait
Bed, hitch and rear cams works in motion, but I need 360 cams works also.
no 360 cams in motion.
This is Vin : 1FTFW1E51MFC37912
GolfR
2022 F150 KR PB
For those who have enabled the cameras in motion, does the rear view camera have a black “full view not available” text box in the middle of it while moving? My 22 came from the factory with the cameras enabled but the rear view is basically unusable because of the box. I’m trying to figure out if any of these changes will get rid of that box.
Thanks
Omodan
Randal
Augusta GA
2021 F150 King Ranch, 2019 Expedition Limited
Can anyone recommend a sub $200 laptop to use for forscan? I’m a MacBook user so I’m trying to make sure I get the right one.
I purchased a Gateway 11” touchscreen laptop from Walmart for $199 specifically for the purpose of using it with FORScan.
https://www.walmart.com/ip/Gateway-...C116-2BK/754399616?fulfillmentIntent=In-store
I use the OBDLink MX2 as the interface to the truck.
https://www.amazon.com/OBDLink-Blue...qid=1646494876&sprefix=OBD2+MX+,aps,73&sr=8-3
This setup has worked great for me.
Jesse-Infotainment
You have a JOB 2 truck. You should have all cams in motion. Also should have cargo cam in the side stack. Plus full screen cargo cam .. I am going to look at your truck history.
Edit. You have the newest IPMA.. You have the correct APIM version you should of had all cams no changes. BUT it looks like you have made some changes.? You cant go by that sheet it is for JOb 1 trucks.
You need to go to 706-04-01 XXXX-X8XX-XXXX
I saw you are in Kuwait... the truck is an actual Kuwait build.. They disabled a lot of the features for that build. You can still try the 04-01 change it will set it to NA and possibly make cams in motion. I do not know if there would be any other impact.
AutonomousHybridF150
Kristopher
Pensacola Fl
2021 F150 Powerboost
Adjuster
I was in the same boat and picked up a a really old one from work that no one used. Runs Vista (which came out in 2007) and it works great with Forscan. Get a used one if you can. I am purchasing one now to try out the FDRS module programing which has much higher requirements.
Which proves that any current new X86 Intel or AMD Windows machine will work fine for FORScan. The program is communicating with the truck at very low speeds, so really any x86 windows machine should work fine.
jcaspar
Sacramento CA
2021 F-150 4x4
That sounds right. The laptop I am using is a Core 2 Duo 1.8GHz with 2 gb ram running Vista Home
ENG430
Ahmad
Kuwait
Unfortunately I tried it. No 360 cams on motion.
Many thanks my friend.
I only change the double honk, Bambi mode, Auto start stop, Global windows and seat belt reminder.
I don't remember I change anything else.
THEREED
New England
2021 F150
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 1646623255995
I am a ForScan newbie who has had success with most of my changes but I did not research the enable camera in motion closely and made the above updates. I have an XLT 302a WITHOUT 360 cameras so making the changes above gave me new menus camera view menus but they obviously don't work and the changes make the hard button above the screen no longer work. My camera works when I go into reverse but the button no longer works even when stopped.
I made the mistake of not backing up my files.... can someone provide me with the original as-built values for the 3 modules above? 2021 XLT 302A without 360 cams
much appreciated
ENG430
Ahmad
Kuwait
much appreciated
https://www.motorcraftservice.com/AsBuilt
Just write your vin number you will get your original as built files.
Jesse-Infotainment
Not for 21. When you change it changes online. These trucks self report. The only module that may not is the BCM all others do. Some of the other vehicles will also with sync 3 if they are on Wi-Fi or are connected.
