daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
So what settings did you use to get this working like this?
I directly applied the ones on the spreadsheet first page of iceman's pinned post at the beginning of this thread. For Job1 cameras in motion.
I know you need the IPMA updated from the one that came with the truck, and I was ready to ask the dealership but he also confirmed in FDRS that I have the latest IPMA and APIM (2 of the biggest modules). They must have come in OTA as my dealer has never touched these.
ROBB1
Justin
NC
2021 F150 Tremor
What changes need to be made in order to enable the Auto temp on the seats?
I have a 502A Lariat.
HVAC
733-01-08 xxxx x1xx xx (Original As-built 0)
APIM
7D0-02-02 1xxx xxxx xx (Original As-built 0)
sysop
Joe
2020 F150 Lariat 145 - 2022 F150 Lariat 157
worker bee
HVAC
APIM
What if your "Original As-built" was not 0? The AB on my HVAC was 4 and these settings do not work for me.
ROBB1
Justin
NC
2021 F150 Tremor
I should have copied my disclaimer from the original post as well for clarity:
My truck is a 2021 402A Tremor which is equivalent to a 502A Lariat. Other trims should verify your original as-build against the spread sheet for possible differences.
If you have “4” in HVAC 733-01-08 xxxx x*xx xx
Use 5
Platinum Peasant
West Sacramento
Can anyone recommend a sub $200 laptop to use for forscan? I’m a MacBook user so I’m trying to make sure I get the right one.
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
That’s the way job one trucks work only job 2 and later get the cargo cam on side stack and full screen and other views at speed
What are the job two version?
My Sync (SYNC4 v4.0.21136)
Will this works with mine?
Eco_Beast
Kevin
Maple Ridge, BC Canada
2022 F150 3.5L EcoBoost
Electrician / Graphic Designer
Hey guys I'm trying to add Rock crawl but I don't see an ABS module anywhere? I've been able to successfully complete a few other things, just can't find the ABS 760 module.
sysop
Joe
worker bee
At that price-point there is a high chance of issues.
itsdchz
Lee
Clovis CA
2021 F150 Powerboost FX4 XLT with Stuff
From the speedo thread. Any info/thoughts would be helpful:
Help??
I have gone from 265/60/20 stock Hankook to 275/60/20 more aggressive Cooper Discoverer ATS. When pulling up my info in a 2021 Powerboost, under BdyCM, I look at the appropriate fields but they do not match:
Stated info from OP: 726-15-01 xxxx xxxx ABxx - This field already contains the correct value in my vehicle: xxxx xxxx 09xx (based on code gen, both sizes have this same value present)
Stated info from OP: 726-15-02 CDxx xxx xxxx - This field only has the parameters in 2 segments, ie: F3xx xxxx
Based on my stock configuration, I should have 726-15-01 as: xxxx xxxx 09xx - this is the same for new parameters as that value did not change - OK
What would I change for 726-15-02? My stock parameters are: F3XX xxxx (no 3rd segment) (the stock parameters in the HEX generator suggests that based on 265/60/20, I should be CD- CDxx xxxx xxxx, even though F3 is present on as built parameter)
The Hex generator states I should have F2 as the new value, however when I replace the F3 to the new F2 value, it states that my checksum is wrong, so I did not write The code and perform the DTC check.
Any ideas if the Powerboost BdyCM and 726-15-02 is different on 2021+ and should only contain 2 segments, not 3, and if I write the F2 value vs F3, if this is truly for the tire size?
Thanks in advance.
In summary:
As built on 2021 PowerBoost - came with 265/60/20 Hankooks- Added 275/60/20 Cooper
I have stock configuration:
726-15-01: xxxx xxxx 09xx
726-15-02: F3xx xxxx
Hex builder states I should have stock configuration as:
726-15-02: CDxx xxxx xxxx
Hex builder with new tires:
726-15-02: F2xx xxxx
Forscan v2.3.46
Gnfghtr
Colorado
2022 F150
Pilot
I cannot find the Power Steering Control Module in Forscan. How can I open it up?
C. Mays
F-150 Lariat; Subaru Crosstrek
Project Management
Ruffiano99
Joe
NY
2021 f150
Anyone know if it’s possible to reset or recalibrate the steering angle sensor through Forscan? Having an issue that my steering wheel is slightly off center while driving. Truck drive and tracks fine. Just bothers me that its not dead center.
Did a level and had an alignment done. Its been like that since, i think, dont remember noticing it beforehand.
jcaspar
Jeff
Sacramento CA
2021 F-150 4x4
I was in the same boat and picked up a a really old one from work that no one used. Runs Vista (which came out in 2007) and it works great with Forscan. Get a used one if you can. I am purchasing one now to try out the FDRS module programing which has much higher requirements.
imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
Sounds like they didn't have the steering wheel straight when doing the alignment. That's the only time I've ever had a vehicle with the steering wheel not centered.
