Option on the Lariat, but delayed due to part availability. If you want them, you dealer can add them to your order, but it will likely delay your truck.What's the deal with these? I am confused, are these special order from the dealer or are they standard on the Lariat and will just come at a later time?
O.k. this is where I was confused. I was under the impression that it would be a dealer installed option after delivery. I wonder if ICE Lariats are being delayed because of this also. I might just go ahead and get the electric running boards, might as well.Option on the Lariat, but delayed due to part availability. If you want them, you dealer can add them to your order, but it will likely delay your truck.
The dealer has to add them. They are not on the online build and price. Only available on Lariat and Platinum.Wasn't even an option when I just did my order.![]()
Your dealer won't install them. It will require different wiring and programming.Oh, I didn't even know it was an option. Can I get them from the dealer after I buy the truck? I don't want it delaying my order.
In addition to above..The fixed running boards have additional zone lighting which isn't available on the ICE retractable running boards. Might make it easier to stomach the tradeoff.
The retractable boards probably have an aero benefit but I'd guess that they'd also carry a weight penalty.
They're standard equipment on the Platinum it seems.For ICE trucks there are aftermarket versions of these. Rumor is that they are having to be designed due to the battery on the Lightning. You would have thought that they would have had a couple of years to do that.
It is correct they are only able to be added by a dealer, but it will also delay your truck. The part that makes them so tempting is that they were only about a $200 add on. I figure most of us would have added them for that price. They likely would have been standard on the Platinum.
You are correct on the ICE version. So far they are not on the Lightning. I believe once the redesign is done and they are no longer on "Late Availability" I believe they will be added as standard equipment to the Platinum and show up as an option on the Lariat on the customer order page.They're standard equipment on the Platinum it seems.
