RapidRedRick
- First Name
- Rick
- Jan 19, 2022
- Northern Virginia
- Ford F150 Platinum Powerboost
I have VCX Nano, when I go to Forscan to load my original backup file it says "Error opening file".VCX Nano will not corrupt your configuration data in As-Built, only the "NODE" data that contain the report from the recent Network Scan (if performed) in FDRS. He should have definitely not load configuration data into the module (if changed in ForScan) prior to PMI. Hope he has a configuration backup. If he does, he needs to load the default configuration back to the module via ForScan, then run a Network Scan in FDRS if he has the Mongoose-Plus device (DO NOT do it with VCX Nano) and then do the PMI.
If he has VCX Nano, do the PMI then restore original configuration with ForScan.
