RapidRedRick
Rick
Northern Virginia
Ford F150 Platinum Powerboost
Using a program called FDRS I updated the software for the DSM module and lost heated steering wheel and heated / cooled seating functions. I ran a comparison of DSM abt data in the truck module to the data on the Motorcraft site and they matched. However, the current DSM abt file has 3 additional blocks and several line differences to the original backup DSM abt file. I have attempted to reload the original backup DSM file but received an error message. I am not sure loading the original backup file will fix it, but I don't know why It wont open the file. I could go into FORScan and manually make the changes, but don't know what to do with the additional 3 blocks at the bottom? Does anyone have a suggestion?
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
If the newer DSM has additional lines you cannot reload the older version with less lines.
Eco_Beast
Kevin
Maple Ridge, BC Canada
2022 F150 3.5L EcoBoost
Electrician / Graphic Designer
Does anyone know is there a way to default to the last driving mode instead of going back to normal every time you start the truck?
superfordman
Troy
NE CO
2021 F150 Lariat
I'd say try to edit the abt file. Paste in all the good values from you old, good DSM file, then make sure all the new values are also in there at the bottom then see if you can load and restore the file then. I would imagine all the newly added values are already configured the way they need to be. I used the same method to load my vin into a new module yesterday and worked just fine and like it should when I loaded and wrote it.
Ford Motor Company
Official Ford Account
Ford
F-150
Good afternoon, Rick! Could you please send us a private message with your VIN and dealership information? I would like to look into these heated steering wheel and seat concerns for you on my end. Thanks!
THEREED
New England
2021 F150
appreciate all the great info here. A couple questions, I have a 2021. XLT 302a, no 360 cam
1) i replaced my taillight bulbs (brake and turn) with LED bulbs (not full unit) and updated in forscan to eliminate hyper flash. I still have halogen front turns. The forscan changes eliminate hyper flash when my headlights are off, howeve, if my headlights are on hyper flash occurs. Thoughts on how to resolve?
2) I do not have bed cam or 360 cam, just reverse and hitch views. Can I enable rear camera at speed? Last time I tried I entered all lines from forscan sheet and it caused issue since I don’t have the additional cameras. Wanted to see if I should only enter a single line of forscan changes due to my camera package
My42waffles
Kegan
21 power boost 157, lightning reservation
Maintenance
I would suggest turning off bulb outage detection for all lights and see if that changes anything since last I knew there was a difference for front and rear lights.
Twilly 3.0
Trevor
Alberta, Canada
2021 F150 3.0L Powerstroke, 2021 Edge SEL
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 20210222_180700
What is with the vehicle icon? I know when cruise and lane keep assist is on it shows it but mine is on all the time. I see some gauges without it. I think I enabled when I first got my truck but I cant remember, it's either that or its the adaptive/intelligent cruise being enabled but it is there whether I have cruise turned on or not.
Livnitup
Livnitup
2021 F150 Platinum
It's lane keeping assist and you have it turned on; press the button on the steering wheel that matches this image telltale and it'll turn off
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? lane keepin
Twilly 3.0
Trevor
Alberta, Canada
I pulled that picture from the interwebs and it looks slightly different, no lines on the side and the front sensing portion shows a vehicle and changes the colour from green to red when in traffic and I’m too close. It is definitely not lane keep assist. I just took these pictures.
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? ECD98E12-467D-46C4-BA9B-54AFA6C85CEF
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 5891FCA5-2265-488E-BFC8-655A6AC164EE
Livnitup
Livnitup
2021 F150 Platinum
The picture above is the Distance Indication feature is turned on under Features, Pre-Collision Assist Menu in Sync so turning that off will remove it.
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? Distance Indication
CJ912
Corey
MI
2021 F150 Platinum 2017 Explorer Sport
Warehouse consultant
Has anybody had success with the 2021s and the Bluetooth version: OBDLink MX+ OBD2 Bluetooth Scanner?
I noticed that they recommend a USB version but I don’t want to use my only laptop (which is a work computer).
can’t wait to turn off the pedestrian back up sounds, every time I come home it wakes my wife up who works hospital hours!
Thanks
jabrego
Jason
Los Angeles
2021 F-150 4X4 Lariat 501A Sport
Thanks
Well you could always make your own adapter or buy one a member sells. I made my own sound delete jumper. for less than $10.
https://www.f150gen14.com/forum/threads/pedestrian-sounder-delete-no-codes-easily-reversible.6066/
https://megaohmmotorsports.bigcartel.com/products
