Bob_Mac
- First Name
- Bob
- Feb 6, 2022
- North Carolina
- 2021 Ford F-150 Platinum
- Occupation
- Cyber Security | Developer
FDRS does not have a manual way to reboot a module. It may do it after a module update or a PMI but I think that's the extent of it.Isn't the PowerBoost auxiliary 7.5Ah battery on a PCM controlled relay which is normally open while the vehicle is off, cold cranking, in generator mode or in auxiliary mode? I had the impression the auxiliary battery circuit only closes to connect to the 12V bus when the PowerBoost is in its drivable 'Ready' state and lots of accessories are all drawing a load at the same time.
What I'm getting at is disconnecting the engine compartment battery in a PowerBoost while it is off should shut down all the ECU's the same as any other F150... or so I thought.
As an FYI though we can manually force modules to reboot through ForScan which achieves the same thing. I think the GWM has a general handshake bug or routing table cache issue of some sort because on more than a few occasions I've encountered modules that need to be rebooted to establish full functionality again after making any changes to their as built parameters.
Does FRDS offer a similar forced ECU reboot diagnostic function? it may save some time for people depending on the circumstance.
