Ebrou
Mobile, AL
2021 F150 XLT SCREW 5.0L Sport 4x4
Ok, I don’t have that option so must be a PTS issue.
At the top of page you have a tab Vehicle, like the below photo. in step 2 you will get the email access option
Ford F-150 Lightning ECU module programming guide using FDRS 1647628882021
Foxtrot150
Houston, TX
2021 302A PB SCrew 6.5
Yo, @Foxtrot150
Get a battery ready :)
So I went ahead and purchased the two day FDRS license and am using a VCX Nano. I'm hooked up to my truck (without doing network scan), but the voltage is only at 12.1 volts (wish you could see this before buying a license). I have a charger hooked up at the max (12A) for battery type AGM but it hasn't changed in about an hour.
Opinions on what I should do? Should I try performing an update?
nicholsbradley
Bradley
Louisiana
2021 Ford F150 Platinum
Analyst
Make sure you headlights are off. Sounds silly but got me
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
One advantage of updating at night is the obvious reminder that the truck resets the headlights to "auto" after you turned them off. 100 times.
Also make sure your charger has really good bite on the appropriate conductor.
Foxtrot150
Houston, TX
Thanks; I readjusted the bite on the positive terminal and ground point, and turned off headlights. Should the truck be in accessories mode when starting? Door open or close?
For my reference, I used JScaro's picture to adjust the connections.
abd79
Wayne
2021 F-150
Weird, my PTS looks different than yours. I’m just accessing mine through the Motorcraft service website.
Snakebitten
Coastal Texas
Yes on accessory mode.
I sat in my truck with door closed. Windows up/down depending on weather.
Turned my lights off 1000 times.
Battery at 10A was enough because it's a Powerboost? But I would have gone to 20A if I saw it was needed.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
What charger do you have? Does it have a power supply mode? If it does, make sure you are in power supply mode, not charger mode. When flashing an ECU, your goal is to maintain voltage, not to charge the battery.
Foxtrot150
Houston, TX
Unfortunately no, it's vintage ;-).
Ford F-150 Lightning ECU module programming guide using FDRS IMG_20220318_145325080
JEB
Northern Illinois
Ok. I know you probably don’t want to hear this, but patience is your friend. Stop and let the charger fully recharge your battery. This way you can (1) ensure your contact points are good and (2) start with as high an initial voltage as you can. When you have a fully charged battery, proceed. Leave the charger on, turn off your headlamps, climate control, heated/cooled seats, heated steering and audio.
Foxtrot150
Houston, TX
Thank you... leave the truck on in accessories mode?
JEB
Northern Illinois
Not while charging. Turn off everything and walk away. Just let the truck fully shut down and leave the charger to do its thing. Check your charger periodically. Once you are fully charged, yes, you’ll do most of the work in accessory mode with the accessories I mentioned off.
topgun964
Robert
Ney Jersey
2021 Ford Raptor
Started my first updated.
GWM asked me to install USB. I Installed it in truck and selected close on the screen. I saw system updating in the top left corner. I walked away and now the system updating is gone. No other message on the screen. Can i assume the update is done?
jmm3807
Phoenix AZ
www.seasavvyaquarium.com
2021 F-150 Platinum 4x4
Business Owner
No. It will tell you when to restart the truck. After restart wait a while and then it will tell you to remove USB.
