Jesse-Infotainment
2021 F150
What I am saying is DO NOT load all from an old back up.. You can make changes but dont load all
Ajzride
Alan
Houston
Eng
Did you pull the USB stick out first? Or did you mean the update no longer appears in the SW tab?
It no longer appears in the software tab, the only thing I have is the GSM procedure. The update failed, but it still cleared itself out and I can't get back in.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Are you referencing changing the
@Bob_Mac yes I made changes for adaptive headlights to the two below
720-01-01. 22FOA 3064 F4EA
720-10-01. 0B18 0061 00BC
Slow down. Do a network scan. Are you getting DTCs? You need to check this FIRST!
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
Can you change the values back to what the originals ones were? If you don't have them then try this as last resort.
720-01-01 2F0A 1064 F4CA
Skier167
Nate
Ohio
2016 f150
@JEB sorry, yes I did a network scan and the module came back green with no DTC’s also the IPC update is still present. All modules are green and no dtc’s present on any module now.
JEB
Northern Illinois
Can you run the IPC from scratch now? Erase the flash drive and start again as if you’d never touched the IPC before.
The IPC is a weird animal. I had made FORSCan changes previously and I was still able to update. But if the standard method doesn’t work, you have work to do. You’ll probably need to have @Bob_Mac walk you through restoring the original configuration and then a CAN bus update. But try the original method first.
Jesse-Infotainment
2021 F150
I hope no one is doing that...
Well When I saw it mentioned someone had a structure mismatch that is why.. So I just wanted to make it clear not to
Bob_Mac
Bob
North Carolina
Please look at what I posted... your FORScan changes could be affecting the update. The last line stays only the first one I posted gets changed. The last 2 of the last block will get recalculated if it's wrong.
Bob_Mac
Bob
North Carolina
Did you make ANY changes to the IPC using FORScan?
Ajzride
Alan
Houston
Eng
Not that I remember. Let me look back through my changes.
EDIT:
I didn't think about these being in the IPC, but I guess they are.
Disable driver & passenger seatbelt minderIPC720-01-01xxxxxx0xxx--
Disable Auto Engine Idle Shutdown of 30 minsIPC720-01-01x*xxxxxxxx--subtract 8 from your default value (if default is F, change to 7)
So I suppose I need to go manually fix those two and then try the PMI again?
