MikeYQM
- First Name
- Mike
- Jul 3, 2021
- Moncton NB Canada
- 2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
I had mine forget it was a hybrid after the insulation recall repair. I believe they drained the HEV and for a drive cycle it wouldn’t go into EV mode. I don’t recall if it fixed itself or if I charged the battery, but it did correct itself and I believe it was caused by low battery.My battery charger was DOA so I didn’t get all of the updates done yet. I had 3 odd issues afterwards. 2 only occurred the first time I drove it after the updates. The last issue is this running board issue.
Message came on that backup brake assist wasn’t available backing out of the garage. Next 2 times in the truck and backing up with no error.
The truck wouldn’t run on battery. I checked the power flow and it showed this message. It was 66 degrees out and I’ve been driving over 7 miles at this point. After we stopped for ~45 mins and left it was back to normal.
If it helps anyone here are the updates I ran last night.
Door module (DDM)
Audio (DSP)
Gearshift (GSM)
Battery Energy Control (BECM)
Anti-Lock Brake System (ABS)
Secondary On-Board Diag module C (SOBDMC)
Power train Control Module (PCM)
Driver Front Seat Module (DSM)
Door Module (DDM) - showed up again and disappeared after this update. 2 updates maybe. Both were successful.
Trailer Module (TRM)
it’s possible yours Is related to doing updates without a charger and it will fix itself.
