John_C
2021 F150 XLT 302A PowerBoost
Did you unplug the module as well? It was stated in the post that detailed how to do it.
No. The spreadsheet states that unplugging the module is only required if changing from a "5" to a "1", NOT a "4" to a "0". Or maybe this is worded wrong, and unplugging the module is required either way?
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? Forsca
imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
I'm not certain, but I think you need to disconnect the PACM regardless of what the default value was.
iceman77
Pete
2022 Ford F-150 Platinum
I can confirm, the PACM needs to be disconnected for it to stop “beeping” when backing up. Setting the IPC in ForScan merely disables the DTC and error message on IPC when the module is disconnected. I just tested it today
John_C
I guess the instructions are just worded a little oddly, I will give it another shot!
Then unplug it I shall. Thanks for the clarification.
JIMFOUNTAIN
2021 F150 SCREW PB 6.5' 701A
I have a 2021 Platinum. Up to date. Bluecruise working. Hitch, Bed and rear cameras now selectable at speed. I have successfully added the Tremor Style Camera (full screen front view at speed with tire locators) as shown in the following in full screen:
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? image_50427137.JPG
This camera comes on in the following MODES: Rock Crawl, Mud/Ruts, and Deep Snow/Sand. Setting IPMA 706-02-02 xxxx xx03 xx-- turns on this Tremor offroad camera feature set.
This change has been tested on updated 2021 Job 1 (pre 7/5/2021 builds) Platinums and King Ranches. With and without factory FX4. But it is believed that 2021 Job 2s and 2022s will work as well.... if you already have rear, hitch and bed cameras at speed.
Usual warnings apply.... Your mileage may vary. Always backup first!
Credits: @Livnitup , @Jesse-Infotainment and many other F150 Gen 14 pioneers. Without you guys this kind of stuff WOULD NOT BE POSSIBLE! Thanks.
FrankThompson
Frank
Sebring, FL
'07 Pontiac Solstice GXP, '22 F150 Lariat PB
Solutions Architect
If only I could remove the "Full view not available" when using the rear view at speed. The only reason I don't have the "full view" is because the stupid box is there telling me that!
jordandev
Jordan
2021 F150 XLT 302A (on order...)
Credits: @Livnitup , @Jesse-Infotainment and many other F150 Gen 4 pioneers. Without you guys this kind of stuff WOULD NOT BE POSSIBLE! Thanks.
Nice find. Tested this on my XLT 302A with 360 and now I do get the front camera turning on when switching to mud or rock crawl automatically (it wasn't before). But no tire indicators like above. Could be because I got stuck at 21281 v244? Or is there something else that could enable that...
Livnitup
Livnitup
2021 F150 Platinum
What is your current value in IPMA here? 706-02-01 xxxx **xx xx--
jordandev
Jordan
Livnitup
Livnitup
2021 F150 Platinum
hotrodmex
Ca
22 Lariat 500.5a
I'm assuming the tire marks also move with the steering wheel? Just checking since haven't seen a pic with them turned, or that specifically being mentioned.
JIMFOUNTAIN
yes the tire marks move when you turn the wheel. And in reverse you get the usual backup markings.
FordConvert
Craig
Utah
2021 F-150 Lariat PB 502A
Builder
Not sure if this has already been discussed, but had some thoughts regarding FORScan changes and OTA updates.
Some Job 1's who manually updated using FDRS from failed OTA to BC ran into problems if they didn't revert FORScan changes in key modules. For those of us who made it to BC and reapplied FORScan changes, what is the risk that future OTA's will cause issues?
Given this I decided to turn off automatic OTA's so I can check what modules have updates and apply them manually after reverting applicable FORScan mods. Call me a control freak but I'd rather control my updates/software TSB's in FDRS than rely on inept service techs or possible software purgatory of my own making ala FORScan. (Seriously took me 20 minutes to do TSB 22-2117 when a tech had failed at it for two days)
I know not everyone wants to invest time/money into a Mongoose or FDRS licenses but for me it's worth it in this brave new OTA world. Also would be nice to avoid the shop if it's just a software issue.
Maybe I'm off. Feel free to shoot this idea full of holes.
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
It worked with me.
But is there away to make 2H works with any mode above?
I have Lariat 502a 2021 Job 2.
jordandev
Jordan
sorry for the full n00b question here because I'm obviously missing something...
downloading my AsBuilt data from the widget (reloaded) or even directly from motorcraft shows me old values. I made the changes in forscan over a week ago now.
Why are they not getting uploaded?
