Sdctcher
- First Name
- Mike
- Jun 18, 2021
- Anywhere-Everywhere
- 2016 Ford Escape, 2022 Ford Lightning Lariat ER
- Occupation
- EV Gypsy
Lots of discussion about using your new Lightning to power your home. But this would require an upfront investment (SunRun or Other) of up to $40,000 for an 8-10 KW System. A system of this size would be required for a larger home. If you do not buy it for cash you will also pay interest and have increasing depreciation over the next 25 years. Also add in some maintenance costs each year. It is debatable on how much value the system will add in home resale value. It depends on the market and finding buyers who value solar.
The value of the system can increase depending on whether your utility allows net metering where they "buy-back" unused energy but currently most of those rates are about 50% of what they charge you for delivering energy to you. Currently, the national trend is many utilities are trying to decrease net metering rates or add surcharges for solar. Also, is your home roof surface large enough (10kw = 600sf of panels) and steep enough (nominal 40%) to accommodate the panels required?
Lightning ER in a Power Outage
Thunder & Lightning and my power goes out for a few minutes or hours on a hot day. So I back up my truck to the house and string enough extension cords to power my fridge to keep my beer cold, run my TV and Modem so I can You Tube the Tornado coming at me, and power my cheap fan to keep Momma cool and collected.
At this point I could describe a method I have done for years (with my generator) although it is both dangerous and stupid unless you know what you are doing. So read on if you are one of these types of person.
I flip my panel utility-to-home disconnect to Off. I plug in my generator NEMA 14-50 outlet to my dedicated NEMA 14-50 panel input circuit (with a 60 amp breaker) in my carport. Normally I use this circuit to run my welder or plug in my trailer. I then just monitor my usage. I cannot run more than one 240v (furnace/dryer/stove/water heater) appliance at a time. I used this method back in 2011 during an 11 day ice storm outage.
OR
I could connect my Ford Charge Staion Pro (Free with Purchase) to my Sunrun Home Integration System ($3,895.00 + Tax) + Installation ($1,000+ ?). And if I want to go all out and impress my neighbors I can add a Solar System (10kw $30,000) and Battery (10kw $10,000) to capture unused solar production to net meter back to my utility at about 50% of their retail cost to me.
Seldom would an outage last longer unless you subscribe to various "Web Facts".
A discussion of the investment value of a related solar system is a whole other matter. It would involve where you live, the configuration of your roof, whether you can even use net metering, maintenance and depreciation costs, home resale value, tax credits (26% and decreasing) and interest costs (5% and increasing) if not purchased for cash.
I demand that people call me an Elder, not Elderly, so I can use the RMD (the required minimum distribution is the minimum amount you must withdraw from your IRA each year) to help pay for my Lightning.
I felt bad that I was cashing in to pay for my frivolous Lightning so instead of paying cash (I am financing for a short period instead) I reinvested it in solar after calculating all the options mentioned above to power my recharging. I have no need to power my home in an emergency because I already have a Generac 22kw Propane (+ a 500 gallon tank loaded with $1.50/gal. gas) Whole Home Generator.
My Solar Purchase (25 Year License) was as follows:
Kentucky Touchstone Energy Cooperative Solar Farm One
46 Panels 5 X 3 Feet (Each 460w Q-Cell @21% Efficiency)
Producing 22,000 kWh/Year (My Annual Usage) 530,000 kWh over 25 Years.
My Cost was $21,160.00.
I am currently credited $0.07/kWh on my bill (the current total retail rate is $0.10/kWh) for my solar production. The difference is they do all maintenance, transmission, and upgrades for the next 25 years. If rates stay the same my return over 25 years will be $31,740. But rates will not stay the same. At an inflation rate of 3%/year my return would be $56,000.00. The utility will buy my production from me at increasing market rates for solar. I have a minimal charge for a buy back and my license will continue for the next 25 years on my farm for my son and his son in case I do not live until age 105. In addition, each year I am credited 22 Solar renewable energy certificates (SREC). (I earn one SREC for every megawatt hour (MWh), or 1,000 kilowatt hours (kWhs), of electricity my solar farm system generates). The SREC value fluctuates in the national marketplace but currently, in my state, it is about $500.00/year, and forecasted to greatly increase in coming years.
My upside is that panels at my home (surrounded by trees) would not work. All solar production is utilized to the max, not just what I use. I do nothing except watch my electric bill decrease to a credit over the years and I charge my Lightning basically for free as long as I charge at home.
This solution worked for me and every individual case is different.
My point is run the numbers. Why would you invest in Sunrun or Solar? What problem are you trying to solve? Does it make sense for you? Believe the Numbers - Not the Hype. Do Not get caught up by emotion.
OR
