Dog Mode
GrokTime
Sean
Ithaca, NY
Toyotas + incoming F150 Lightning
I think it is relevant in that ford is obviously anticipating dogs being in some F150s.
F150LER
Us
F150L
Prob the same thing but I noticed when I’m using the pro power it turns off the default timer and I turn the lights and air off. Didn’t test for dog mode to see if air stays on.
UPDATED DIY DOG MODE INSTRUCTIONS
I’m posting revised Dog Mode instructions based on input from a number of you. Bottom line, these new instructions (a) allow you to leave the Remote in the car (if you want to) AND (b) assure that the doors are locked!
  • AC / Heat On: Be sure it’s set to “Auto” and to, say, 73 degrees.
  • Truck On: Leave the Truck Running.
  • Lights to Off: Turn the dial to the left until it’s “off”.
  • “Power Down” Timer Off: Turn Off the 30 second “Vehicle Power Down Timer”: Note, if you shut the truck off by mistake during this process, you MUST repeat this step. This step is required every time.
    • Truck Image
    • “Settings”
    • “Vehicle”
    • Turn off first setting, “Vehicle Power Down” – This must be manually toggled to “Off” EVERY time (because when the car is shut off, this immediately “resets” to “Timer On”.)
  • Manual Paper Sign: I put a “Dog Mode” sign over the display.
  • Open Door: Dash will say, “Truck is Running.” Ignore or press “OK”.
  • Exit: You can take the Remote OR you can leave the Remote.
  • Lock Truck: Lock the truck by simultaneously pressing the “9-0” and “7-8” buttons on the “Keyless Entry Keypad” (on the door jam.) Confirm truck is locked by confirming the traditional door lock “knobs” are down after closing all doors. If the truck double chirps, it is NOT locked.
  • Confirm Running: Confirm the truck is still running. (The dashboard should look like it does when you are driving.)
FirstF150InCasco
Boston MA
If you follow the instructsions I typed up, it works perfectly. I did it again yesterday. I did set a 30 minute timer on my phone and I left the grocery store just to make sure the 150 didn't power off after 30 minutes. It was still running. I'll be happy when Ford releases dog mode; it's a pain to step through my instructions each time!!
RedLightning86
Wisconsin Dells
You can just leave the truck running, BUT, you have to turn off the 30 minute count down timer EVERY time. It won't stay off just by setting it once.
queuewho
Western PA
F150 Lightning Lariat SR
My checklist before leaving them to run in a store real quick:
Lights off
Power down timer off
Interior Motion sensors off
Fold in mirrors
Lock the doors
Hasn't really failed yet. Only leave them for 15-30 min if I do. I try to still avoid leaving them on very hot days, because some Karen will break my windows to 'save' them because she can't hear the truck running.
Item 3 probably isn't needed since the vehicle is on. I just do it out of habit because I got burned by it when I left the truck off while charging on a cool day, came out to some scared doggies and the alarm going off.
Use sketch pad to write note...
FirstF150InCasco
Boston MA
It’s more complicated than that. I posted detailed step-by-step instructions back in June 2022.
