OTA 3.5.2
Drillerr
Darin
Utah
2019 Ram Limited
My build date was 8/10 and it was delivered 8/25. The update was installed today 9/7. I have not received any prior updates before this one.
adoublee
Midwest
2 EVs
I had a early May blend date. I don't see PAAK indication anywhere in Firdpass app after update. Where would it be - Vehicle tab -> Features and Settings?
Also, I've never had any data populate in Charge Logs. Is this a known issue?
7/25 build week and later are reporting success with PaaK, anyone with an earlier build got it working?
gsquirrel02
Andre
Hampton Roads, Virginia
2022 Lightning Lariat ER, 2020 Pathfinder
I don't have that...mine says System Update and says I'm up to date. On another note, this truck with AA and iHeart radio seems to have drained my phone battery. I guess I will need to update my charge strategy(none before today).
Mine is the same as yours - has never shown anything different - even though my FordPass app says I've been updated to 3.5.2.
Ford F-150 Lightning OTA 3.5.2 IMG_20220908_101717
Maybe SYNC version makes a difference?
Ford F-150 Lightning OTA 3.5.2 IMG_20220908_102626__01
Touch that blue up arrow over to the right of "Update Details".
Ford F-150 Lightning OTA 3.5.2 1662648976630
tomjackbear
Western MA
Hyundai Sonata, Honda HRV, Ford F150L
The "Update Details" menu item will display the last OTA update for some time (few days? a week?) then will move to just display "Your system is up-to-date".
From reading on here and the Mach-E forum there is no way to tell what the currently installed Power-Up version is. I believe the dealer's OASIS system can tell which updates have been applied to a VIN but that is not an easy way to get the information.
gsquirrel02
Andre
Maybe it shows that on some vehicles, but it has never shown anything other than "Your system is up-to-date" on mine, and I check fairly regularly as I've been expecting it to change. Maybe I missed it, but I don't think so.
ChrisCon
The Hamptons, NY
Just wanted to share that trucks with earlier build dates (Mine was 5/19) will not have PAAK enabled on the 3.5.2 update.
A following update (though not necessarily the next) that is expected to occur within a month will enable PAAK for the earlier builds. There is no reason to attempt resets on your phone or truck to get PAAK to work at this point if you are on an earlier build.
As always- Grain of salt because you don't know me , but I'm confident in the source of my information.
Running out the garage like Forest Gump
Gave it a try today, PaaK was a no-go as expected after numerous posts and a couple DM's.
Older builds won't be able to use this feature until a subsequent update is sent out.
This reminded me I have OASIS access...shows I have 3.2.0 pending as of 1:33 today.
Good luck with that and please let us know if you can get it to apply. 3.2.0 is an APIM update. Mine downloaded on August 8 - a month ago, but never gave me an option to apply. I can use Forscan and reset the module and get it to give me a pop up on the phone again, but never get an apply button in Sync.
I have it from a good source Ford is aware of this sitting there and not applied.
Let us know what you are able to make happen and if you can get that update applied however.
By the way - my truck has all of these updates waiting. I can already tell in another month or two I'm going to have to break down and invest in FDRS.
Ford F-150 Lightning OTA 3.5.2 1661818912825
DiveMan911
R.J.
Maui, HI
'06 Acura TL, '13 Ford Escape
Flight Nurse
PAAK is getting a lot of attention on this thread, and I too am an earlier build date and it’s not working: I want it, but It’s not worth me getting upset about.
So…I’m going to shift gears: I had heard that there was a change in one of the updates: either 3.3 or 3.4 that affected the 1-pedal drive. I went from 3.2 to 3.5.2 and I haven’t noticed a difference in the 1-pedal drive “aggressiveness”. Thoughts?
F150ROD
U.S. Navy Retired
How often are you driving? There was definitely a big change on when regen kicked in. Before it was once you started lifting off the accelerator it would start kicking in, now it’s once you are almost fully off that it starts kicking in and comes on smoother.
2000Firehawk
I agree with this. I drive with 1PD on all the time. It was very aggressive upon even the first move up with the pedal. Not that it was bad, but was a little harder to modulate. Now it seems to allow the pedal to come up quite a bit before the regen kicks in. Haven’t had a chance to put a ton of miles on yet of course. Interestingly enough, my wife drove the truck yesterday for about 75 miles with 1PD on because I forgot to turn it off and didn’t mention any negative comments. With the original 1PD she absolutely hated it.
Labs4Lightning
C
I went to hardwired usb connection
DiveMan911
R.J.
Maui, HI
Flight Nurse
I’ve done a reasonable amount of driving around town, when one pedal drive would be most utilized and I would argue I’m fairly sensitive to things in my vehicles, but I have not noticed a difference. 🤔
