Mike G
- First Name
- Mike
- Jan 6, 2022
- N. AL, USA
- 2022 F-150 Lightning, 2023(J1) Mach-E GT-PE
14 Sep.
While checking VINs for some folks last night I ran my Lightning's VIN and was surprised to find updates for the GWM and RFA. If I had to guess, and as yet it is still just a guess, I would think these two would enable me to setup PAAK (if I were so inclined).
So I got up early and put the charger/powersupply on to put a charge on the 12V before starting (it was at 50% having not been connected to the EVSE for a couple of days), and went to make coffee.
Got the laptop, Mongoose, and thumb drive out and first did the RFA cause it's CAN bus programmed, and then ended with the GWM cause it's USB and you have to shutdown and wait 5 minutes before starting the truck back up to confirm success.
Started at 0603 and finished at 0629.
GWM was at ML3T-14H021-HMB and now is -HMC
RFA was at NU5T-14G623-CJ and now is at -DC
Haven't seen anything in FP yet to indicate whether or not I can setup PAAK, but I only just got finished and it may take a while for that to show up if that's what was enabled.
If you routinely find yourself removing and reinstalling the jump point cover to the right of the frunk tub you may find that the plastic turnlock fasteners tend to separate into their upper and lower halves after a while. To keep from losing any of them I put a small dab of superglue in the notch where the little plastic tab is that's designed to keep the thing together. Just so I don't have to worry about them getting lost under the frunk space somewhere. You can see where I put the glue (shiny bit).
Oh, and make sure you let the glue dry thoroughly before reinstalling otherwise it may bond to the surround trim and be very hard to get off next time.
