Your Mileage May Vary
bosox8
Charles
Sales
So about 5,000 miles on the truck now, probably about 60 / 40 driving highway / city. Charged up overnight in Maryland at home and full range indicated 266 miles with an overnight temp of 46 degrees. I've read enough on these forums and other places to know weather impacts range and the indicator may change if I reset my driving history. Nevertheless, pretty disappointed to see the level of decline this early into Fall from a summer re-charge indicating 300+ miles. This is a pretty substantial drop in anticipated mileage - anyone else?
duncanmaio
Duncan
Norwood, MA
In my anecdotal observations over the past week or so with reduced temperature, it seems the Guess-o-Meter is being very conservative. I haven't done any math, but I am definitely getting more range than the truck predicts when I first get in on cold mornings.
Yep. Use the actual M/kWh to gauge the range, not the GOM.
Ian
Ian
Buick Enclave
Help me understand the charging. I’m in Maryland too. Should I be charging to 100%
heelyeah
Tripp
NC
21 Bronco; 22 F150 Lightning; 21 Jeep JT (wife's)
No. Only when necessary for longer trips. Set a cap at 80 or 90 for daily charging needs.
Reactions: Ian
LightningShow
MA
'22 Lariat ER
Product Development
It’s been in the 40s in the morning here and my efficiency has definitely dropped a bit but I haven’t paid too close attention the actual numbers. I think 10% is probably in the ballpark.
pstansel
Paul
Tolland, CT
F150 Lightning Lariat ER, Hyundai EV6
Might want to reset that :)
LightningShow
MA
'22 Lariat ER
Product Development
Mine is saying 192 miles at 75% this morning. That would extrapolate to 256 at 100%. I think its typically been estimating 290ish at 100%. Considering the drop in temps in the recent 1-2 weeks, I think 256 is pretty reasonable. Mind you, I've been getting more like 300-330 based on mi/kWh. So 256 is probably more like 270-300 in actual range.
SmokingtheMeats
PA
2010 F-150
Tech
I'm currently at 73% and 217. It was 49 deg here last night.
sotek2345
Engineering Manager
sotek2345
Engineering Manager
SR in MN. Think it was at a few degrees below zero.
Yeah, ours was at -10F. Upstate NY with a little snow on the roads too.
