No such chart would be possible, because speed is only one of many factors influencing miles per kWh. Other factors include - temperature, weather (i.e. rain), change in altitude (going up or going down), etc.I had an “aggressive” 90mile drive this weekend. 75-85 MPH. Good weather, no ac or heat. My trip usage was 1.7m/kwh… That sound right? Has anyone done a chart showing usage rates vs/ MPH? (I have a platinum ER). Thanks
Preconditioning will raise up the efficiency of a commute. However, it won't raise up the efficiency of a day trip, because the battery will cool during the drive between each charge stop. So the first leg will be the most efficient, assuming a static air temperature.Sounds normal to me. At 75 mph, on my morning commute this week in the 30"s and 40's, I was seeing 1.6mi/kWh with no preconditioning.
This past February when the sunrun sales guy stopped by he recently purchased a model y performance. His drive up from New Jersey to the Burlington VT area netted him a range in the low 100s. It was 0F. Even if he was exaggerating, it is far from 1 to 3 percent. I don't know if he still has to be Tesla. I see his other car (Blue Maserati Ghibli) around.Tesla's only lose 1-3% of range in the winter (supposedly). The mach-e loses 28% in the same conditions which is absolutely terrible. If the Lightning loses 28% too, that would be a major blow to its utility. Hopefully they've improved that. We should know soon.
Tesla's don't lose 1-3% in the winter, unless we're talking winter in the Florida Keys.Tesla's only lose 1-3% of range in the winter (supposedly). The mach-e loses 28% in the same conditions which is absolutely terrible. If the Lightning loses 28% too, that would be a major blow to its utility. Hopefully they've improved that. We should know soon.
The change in battery capacity itself is more than 10%.Yeah, fair, some stuff online says less than 1% but who knows what test conditions. Still, less than 10% loss down to 14F sounds pretty good. If you live in a place that gets to -30C, well, that's just poor planning.
Hopefully for long trips where the battery heating is amortized, the hit won't be 30% on the Lightning. I don't think I'd consider buying one in a cold climate if the loss was that great.
No true. Consumer Reports just tested. For those interested in the full article, you should be able to access CR for free via your library's website.Tesla's only lose 1-3% of range in the winter (supposedly). The mach-e loses 28% in the same conditions which is absolutely terrible. If the Lightning loses 28% too, that would be a major blow to its utility. Hopefully they've improved that. We should know soon.
