Lytning
Regardless of what Codes allow, we need to monitor how our specific installation is reacting. I had a Licensed Electrician install a 50 amp circuit breaker and 14-50 receptacle in my garage for the Mobile Charger. When the Charge Station Pro arrived, I had the electrician install a plug on the CSP and connected it to the 14-50 receptacle. He set the CSP at 40 amps per Code allowance. The plug temperature was running at ~100 degrees F and the circuit breaker at ~120 degrees F when charging. Since I can allow charging to complete overnight, I reset the CSP to 32 amps. The plug temperature dropped to ~80 degrees F and the circuit breaker to ~100 degrees F during charging. I sleep better at those temperatures. Estimates to upgrade my electrical system to allow CSP 80 amp charging where in the $12,000 to $16,000 range.
